Re: Interior heat, what do you use?
[Re: Dragula]
#3074178
09/04/22 12:13 PM
09/04/22 12:13 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
Try using Microspheres...mix them into some paint and apply to the floors/firewall. will provide a layer of thermal and vibration dampening.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: Dragula]
#3074386
09/05/22 07:39 AM
09/05/22 07:39 AM
Posts: 8,026 Tulsa OK
Bad340fish
Tulsa OK
I use stock carpet in mine. I need to get a headliner in my car, its the leading cause of becoming medium rare in the staging lanes.
After a few hours on the road EVERYTHING is hot. 2013 is probably the hottest drag week I have done. There was a day where you couldn't hold onto the cage because it was so hot.
68 Barracuda Formula S 340
[Re: Dragula]
#3074650
09/06/22 03:06 AM
09/06/22 03:06 AM
Posts: 1,111 Usa
A39Coronet
Usa
How much could carpet weight? The stock front half weighed a bunch...I want to put down somthing lighter when I redo the interior. I think you can get it with or without the jute backing pad. Jute free probably much lighter but loses some of the insulation obviously. Still retain oe look if that's at all a concern.
[Re: A39Coronet]
#3074713
09/06/22 10:04 AM
09/06/22 10:04 AM
Posts: 12,387 Taxes & Virus's R-US, NY
Dragula
How much could carpet weight? The stock front half weighed a bunch...I want to put down somthing lighter when I redo the interior. I think you can get it with or without the jute backing pad. Jute free probably much lighter but loses some of the insulation obviously. Still retain oe look if that's at all a concern. Is that the crap on the back side of it that I have to vacuum out from every nook and cranny? That might be an option if they offer it that way...The front piece was really heavy for carpet. I have not removed the back piece yet. I just want nice thin carpet, but I need somthing underneath for the heat. I don't care about the sound, the car is loud as ..... anyways.
[Re: Dragula]
#3074727
09/06/22 10:59 AM
09/06/22 10:59 AM
Posts: 10,022 MN
JERICOGTX
MN
The jute backing is where most of the weight is. I scraped all of mine off in the Road Runner. The cheap lightweight carpet, never looks good IMO.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#3074743
09/06/22 11:50 AM
09/06/22 11:50 AM
Posts: 16,479 On the run…
BloFish
On the run…
I used marine carpet to save weight.
It really doesn't matter whether you win or lose… as long as you look good doing it!
‘65 A100 ‘69 ‘Cuda ‘73 Vega GT ‘06 Mega Cab ‘14 Mercedes SLK
[Re: BloFish]
#3076243
09/11/22 08:22 AM
09/11/22 08:22 AM
Posts: 1,629 pa
572charger
pa
dynamat 70 % quieter in side the car and much cooler
606 hemi pump gas best 9.60 at 142mph on motor 05 hemi daytona 1500 go-mango 4wd quadcab 2007 hotrod mag pump gas drags runner up, roadkill nights dodge big tire winner 2018 2019 back to back
