Disc brake spindles #3075395
09/08/22 06:56 AM
09/08/22 06:56 AM
Sweden , Enköping
Rasmus Vestlin Offline OP
Sweden , Enköping
Hello,
I am switching from my Rightstuff 4 wheel disc kit to willwood disc kit on my -70 dodge challenger. I was hoping that i could use the spindles i got from Rightstuff, but it seems that the shaft is bigger and the bearing is smaller on the willwood kit. So it wont slide on the spindles.
I think i need to find and mount OEM spindles to make it fit, the problem is.. where can i find orginal disc brake spindles to a -70 challenger? All help is really helpfull! I live in Sweden so finding orginal parts is a bit harder here. The first picture is on the messurment on the spindle shaft and the other is the messurment on the willwood bearing.
Thanks!
Re: Disc brake spindles [Re: Rasmus Vestlin] #3075399
09/08/22 07:30 AM
09/08/22 07:30 AM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Might be easier and cheaper to have a machine shop modify your spindles.
Re: Disc brake spindles [Re: Sniper] #3075402
09/08/22 07:59 AM
09/08/22 07:59 AM
Sweden , Enköping
Sweden , Enköping
If i cant find orginal disc brake spindles, maybe i Will do it. But i dont know if its anything more that is different on rightstuff spindle contra an orginal one. Would be waste of time to get it machined and then something else dosnt work.
Re: Disc brake spindles [Re: Sniper] #3075405
09/08/22 08:27 AM
09/08/22 08:27 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I thought one of the Wilwood kits required the use of a stock drum spindle.
Re: Disc brake spindles [Re: burdar] #3075407
09/08/22 08:32 AM
09/08/22 08:32 AM
Sweden , Enköping
Sweden , Enköping
Yes they sell to use with factory drumbrakes cars and also to cars with factory discbrake spindles. But i was stupid and sold my orginal discbrake spindles years ago, then i bought the rightstuff kit and got theirs spindles. But they are not the same as the originals apperntly.
Re: Disc brake spindles [Re: Rasmus Vestlin] #3075410
09/08/22 08:40 AM
09/08/22 08:40 AM
central CT
cudazappa Offline
cudazappa  Offline
central CT
It looks like the rightstuff kit uses the 73+ spindle. Do you have the option of exchanging your wilwood kit for one that will work with a 73+ factory disc spindle?
I have 1 70-72 spindle I've been tripping over for years, i don't even remember which side now.
1971 Challenger
Re: Disc brake spindles [Re: cudazappa] #3075421
09/08/22 09:25 AM
09/08/22 09:25 AM
Sweden , Enköping
Sweden , Enköping
Yes that is what iam thinking to.. i wonder why willwood dosnt sell their stuff with the larger bearing as from 73 and up?.. i cant send it back.. its to much trouble with shipment and cost.. do you think it would be possible to machine down the right stuff spindle so its the same size as the 70-72 spindles? I would buy them of you but i need both sides smirk
Re: Disc brake spindles [Re: Sniper] #3075468
09/08/22 12:09 PM
09/08/22 12:09 PM
central il.
second 70 Offline
second 70  Offline
central il.
Dr. Diff
Re: Disc brake spindles [Re: second 70] #3075477
09/08/22 12:38 PM
09/08/22 12:38 PM
Sweden , Enköping
Sweden , Enköping
Originally Posted by second 70
Dr. Diff
What about him? Do he sell 70-72 spindles?
Re: Disc brake spindles [Re: Rasmus Vestlin] #3075481
09/08/22 12:41 PM
09/08/22 12:41 PM
Andrewh Offline
Andrewh  Offline
Dr. Diff
he might, or he might have an adapter bearing you can use instead of having to buy whole spindles.
check his website and email him.
https://www.doctordiff.com/
Re: Disc brake spindles [Re: Rasmus Vestlin] #3075486
09/08/22 12:48 PM
09/08/22 12:48 PM
AndyF Offline
AndyF  Offline
The early spindles with the small bearings are fairly easy to find. Post a parts wanted ad and you find plenty. I used to have boxes of those things but I've scrapped most of that stuff over the years.
Re: Disc brake spindles [Re: Andrewh] #3075499
09/08/22 01:34 PM
09/08/22 01:34 PM
Sweden , Enköping
Sweden , Enköping
Dr. Diff
Okey i have mailed him now and asked!
Re: Disc brake spindles [Re: AndyF] #3075501
09/08/22 01:35 PM
09/08/22 01:35 PM
Sweden , Enköping
Sweden , Enköping
Okey Will try that, bummer that you dont have any pair left..
Re: Disc brake spindles [Re: Rasmus Vestlin] #3075550
09/08/22 04:21 PM
09/08/22 04:21 PM
Sweden , Enköping
Sweden , Enköping
Is it dangerus to machine down my spindles to fit smaller bearing? Or do you think it will be fine? 🧐 dont want it to break.
Re: Disc brake spindles [Re: Rasmus Vestlin] #3075559
09/08/22 05:01 PM
09/08/22 05:01 PM
BDW Online content
BDW  Online Content
Why not get the larger hat from Willwood?
Aren't those 2-piece rotors?
Re: Disc brake spindles [Re: BDW] #3075561
09/08/22 05:05 PM
09/08/22 05:05 PM
Sweden , Enköping
Sweden , Enköping
Didnt think of that, but will the 11” rotors fit a larger hat then? They are 2-piece rotors.
