Re: Disc brake spindles
[Re: Sniper]
#3075402
09/08/22 07:59 AM
09/08/22 07:59 AM
Posts: 19 Sweden , Enköping
Rasmus Vestlin
Sweden , Enköping
Might be easier and cheaper to have a machine shop modify your spindles. If i cant find orginal disc brake spindles, maybe i Will do it. But i dont know if its anything more that is different on rightstuff spindle contra an orginal one. Would be waste of time to get it machined and then something else dosnt work.
[Re: burdar]
#3075407
09/08/22 08:32 AM
09/08/22 08:32 AM
Rasmus Vestlin
Sweden , Enköping
I thought one of the Wilwood kits required the use of a stock drum spindle. Yes they sell to use with factory drumbrakes cars and also to cars with factory discbrake spindles. But i was stupid and sold my orginal discbrake spindles years ago, then i bought the rightstuff kit and got theirs spindles. But they are not the same as the originals apperntly.
[Re: Rasmus Vestlin]
#3075410
09/08/22 08:40 AM
09/08/22 08:40 AM
Posts: 801 central CT
cudazappa
central CT
It looks like the rightstuff kit uses the 73+ spindle. Do you have the option of exchanging your wilwood kit for one that will work with a 73+ factory disc spindle?
I have 1 70-72 spindle I've been tripping over for years, i don't even remember which side now.
1971 Challenger
#3075481
09/08/22 12:41 PM
09/08/22 12:41 PM
Andrewh
What about him? Do he sell 70-72 spindles? he might, or he might have an adapter bearing you can use instead of having to buy whole spindles. check his website and email him. https://www.doctordiff.com/
[Re: AndyF]
#3075501
09/08/22 01:35 PM
09/08/22 01:35 PM
Rasmus Vestlin
Sweden , Enköping
The early spindles with the small bearings are fairly easy to find. Post a parts wanted ad and you find plenty. I used to have boxes of those things but I've scrapped most of that stuff over the years. Okey Will try that, bummer that you dont have any pair left..
[Re: BDW]
#3075561
09/08/22 05:05 PM
09/08/22 05:05 PM
Rasmus Vestlin
Sweden , Enköping
Why not get the larger hat from Willwood? Aren't those 2-piece rotors? Didnt think of that, but will the 11” rotors fit a larger hat then? They are 2-piece rotors.
