Re: Double prong ballast resistor
[Re: moparz]
#3070147
08/21/22 12:57 PM
08/21/22 12:57 PM
Posts: 6,306 nowhere
Sniper
nowhere
Do you mean two prong or four? All ballasts resistors are rectangular in shape. If you mean 2 prongs, in total http://www.moparts.org/Tech/Archive/elec/4.htmlIf you mean the 4 prongs, total According to the 73 FSM coil side 0.50-.\0.60 ohms control side 4.75-5.75 phms.
[Re: Sniper]
#3070148
08/21/22 12:58 PM
08/21/22 12:58 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
Do you mean two prong or four? All ballasts resistors are rectangular in shape. If you mean 2 prongs, in total http://www.moparts.org/Tech/Archive/elec/4.htmlIf you mean the 4 prongs, total According to the 73 FSM coil side 0.50-.\0.60 ohms control side 4.75-5.75 Ohms.
[Re: Sniper]
#3070241
08/21/22 06:59 PM
08/21/22 06:59 PM
Posts: 2,815 Sobieski Wi
bee1971
Sobieski Wi
What year did they change the coil side from .5 OHM to 1.2 OHM
Both are factory Mopar 387467 part numbers
One has the open back .5 OHM
One has the closed back 1.2 OHM
1971 Dodge Charger Superbee 2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded Siberian Huskies
[Re: bee1971]
#3070244
08/21/22 07:03 PM
08/21/22 07:03 PM
bee1971
Sobieski Wi
Standard Product aftermarket is 1.2 OHMs
