Double prong ballast resistor #3070136
08/21/22 12:26 PM
08/21/22 12:26 PM
Edmonton AB, CAN
moparz Offline OP
moparz  Offline OP
Edmonton AB, CAN
Could find anything in search.
Anybody know how/what readings would be for a bench test of a double prong (rectangular) ballast resistor?
Thx in adv!
Re: Double prong ballast resistor [Re: moparz] #3070147
08/21/22 12:57 PM
08/21/22 12:57 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Do you mean two prong or four?
All ballasts resistors are rectangular in shape.
If you mean 2 prongs, in total
http://www.moparts.org/Tech/Archive/elec/4.html
If you mean the 4 prongs, total
According to the 73 FSM
coil side 0.50-.\0.60 ohms
control side 4.75-5.75 phms.
Re: Double prong ballast resistor [Re: Sniper] #3070148
08/21/22 12:58 PM
08/21/22 12:58 PM
control side 4.75-5.75 Ohms.
iagree
Re: Double prong ballast resistor [Re: Sniper] #3070207
08/21/22 04:34 PM
08/21/22 04:34 PM
Edmonton AB, CAN
moparz Offline OP
moparz  Offline OP
Edmonton AB, CAN
Oops. 4 prong.
(Was thinking per side incorrectly)
Thx
Re: Double prong ballast resistor [Re: Sniper] #3070241
08/21/22 06:59 PM
08/21/22 06:59 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
What year did they change the coil side from .5 OHM to 1.2 OHM
Both are factory Mopar 387467 part numbers
One has the open back .5 OHM
One has the closed back 1.2 OHM
3E67C174-7C41-464A-BB76-7871EAD31BBF.jpeg9CDE6FC3-C661-46B5-8E29-0439D1FDF6FE.jpeg8C4FD7D4-2713-4D41-B969-C0D0954F7577.jpeg
1971 Dodge Charger Superbee
2011 Ram Sport 1500 Quad Cab Deep Water Blue Loaded
Siberian Huskies
Re: Double prong ballast resistor [Re: bee1971] #3070243
08/21/22 07:01 PM
08/21/22 07:01 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
.5 OHM
B29F90A8-45E0-4455-AB4F-7E868CFB0192.jpegB08075A1-8E4A-40E0-A819-F28C4F4A5F59.jpeg63ACAE03-A343-4B7F-A143-EE5775E3FFC5.jpeg
Siberian Huskies
Re: Double prong ballast resistor [Re: bee1971] #3070244
08/21/22 07:03 PM
08/21/22 07:03 PM
Sobieski Wi
bee1971 Offline
bee1971  Offline
Sobieski Wi
Standard Product aftermarket is 1.2 OHMs
Siberian Huskies
Re: Double prong ballast resistor [Re: bee1971] #3070388
08/22/22 10:06 AM
08/22/22 10:06 AM
Edmonton AB, CAN
moparz Offline OP
moparz  Offline OP
Edmonton AB, CAN
Learned something new
That’s quite a difference!!
Why the change?
