Ranco heater valve rebuild ? #3066783
08/10/22 11:16 AM
08/10/22 11:16 AM
NORTHERN VA
THESHAKERPROJECT Offline OP
NORTHERN VA
Called the guy in CA that did them but phone number disconnected...sooo does anybody else rebuild the Ranco type heater control valves these days ?? Thanks .
Re: Ranco heater valve rebuild ? [Re: THESHAKERPROJECT] #3066789
08/10/22 11:41 AM
08/10/22 11:41 AM
Calgary, Alberta Canada
a12rag Offline
a12rag  Offline
Re: Ranco heater valve rebuild ? [Re: a12rag] #3066796
08/10/22 12:15 PM
08/10/22 12:15 PM
NORTHERN VA
NORTHERN VA
......I did call them . They said over $300 to restore my valve . Kinda high price so looking for other options .
Re: Ranco heater valve rebuild ? [Re: THESHAKERPROJECT] #3066843
08/10/22 03:05 PM
08/10/22 03:05 PM
North Carolina
469runner Offline
469runner  Offline
North Carolina
This guy did mine a few years ago. Jim Tucker. Is his number disconnected? https://www.heatercontrolvalve.com/
Re: Ranco heater valve rebuild ? [Re: 469runner] #3066859
08/10/22 04:30 PM
08/10/22 04:30 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I did mine myself, DMT has a rebuild kit
Re: Ranco heater valve rebuild ? [Re: CSK] #3066887
08/10/22 06:20 PM
08/10/22 06:20 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
Wow. Didn't know he offered that. https://www.detroitmuscletechnologies.com/misc-heater-ac-related/ and one of them https://www.detroitmuscletechnologi...or-large-3-4-or-small-5-8-od-leg-valves/
What's a Ranco heater valve look like?
He lists a bunch of OE part numbers. I have no idea what mine are. I guess I'd have to dig through the parts book or find an aftermarket listing that included the part number.
Might be helpful to show a picture of the style of water valve to know if I should pursue it. I think many have the same basic design, but with different mounting brackets and actuators.
Re: Ranco heater valve rebuild ? [Re: autoxcuda] #3066996
08/11/22 07:45 AM
08/11/22 07:45 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
This is how the AMC guys do it.
RANCO valve rebuild
Re: Ranco heater valve rebuild ? [Re: 6PakBee] #3067023
08/11/22 10:45 AM
08/11/22 10:45 AM
NORTHERN VA
NORTHERN VA
Found a guy on E Bay that does them , delcojoe in WI. Sent it to him yesterday . I think the phone line was down for the guy in CA because I tried it today and it is working ?
Re: Ranco heater valve rebuild ? [Re: 6PakBee] #3067213
08/11/22 11:57 PM
08/11/22 11:57 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
RANCO valve rebuild
Need to be a member to access that page ;(
Do you have a screenshot from there of what the basic Ranco looks like?
Re: Ranco heater valve rebuild ? [Re: autoxcuda] #3067302
08/12/22 10:51 AM
08/12/22 10:51 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
RANCO valve rebuild
Didn't realize that. It sucks. But moving ahead, here is one AMC version of the Ranco valve. And as you surmised, they are pretty much the same other than the brackets. So that is for the most part what a "rebuild" consists of, moving the brackets.
Re: Ranco heater valve rebuild ? [Re: 6PakBee] #3067589
08/13/22 11:29 AM
08/13/22 11:29 AM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
RANCO valve rebuild
Are the rubber parts the DMT sells are for if you take your original valve unit apart?
I found that new four seasons 74661 unit in gold cad. Looks like the stock unit.
Anytime you have two different places or even batches of gold cad done, often time they don't match 100%. Because these parts are connected, any differences will stand out more. That's if it matters to you. Point is, I can see the value of rebuilding your old one with the DMT parts.
Re: Ranco heater valve rebuild ? [Re: autoxcuda] #3067650
08/13/22 02:31 PM
08/13/22 02:31 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
The Ranco valve I am talking about is like this
Re: Ranco heater valve rebuild ? [Re: CSK] #3068025
08/14/22 10:44 PM
08/14/22 10:44 PM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Completely different animal. Completely.
Re: Ranco heater valve rebuild ? [Re: THESHAKERPROJECT] #3069435
08/19/22 08:32 AM
08/19/22 08:32 AM
Wausau,Wisconsin
Kilrbee Offline
Kilrbee  Offline
Wausau,Wisconsin
https://www.heatervalves.net/
Joe will rebuild your valve fast.
