Ceramic bearings #3067070
08/11/22 01:17 PM
08/11/22 01:17 PM
fredericksburg,va
cudaman1969 Offline OP
fredericksburg,va
Question about them. Are they just ball bearings or are tapered made. Do they run in a steel grove or is that ceramic too? I know they’re pricy but for a dedicated drag car chasing a number it might be worth it.
Re: Ceramic bearings [Re: cudaman1969] #3067091
08/11/22 02:47 PM
08/11/22 02:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
All of themI have used are ceramic ball bearings in a steel cage. Been using them for years and we have had some issues with pinion bearings...As for whether they are worth it or not that has something that has had mixed reviews from many. makes the car easier to push for sure but as for it showing in the slip, ehh...FWIW you can use a micro blue bearings which is also a very low drag bearing for much less money. We have gone to those for all the heavy load stuff for sure. At one point we had ceramics all over the car. Then they became much harder to get and since then the quality has not been the same. My understanding is the ceramic material is from overseas now.
Re: Ceramic bearings [Re: Al_Alguire] #3067094
08/11/22 02:54 PM
08/11/22 02:54 PM
fredericksburg,va
fredericksburg,va
Thank you for that info
Re: Ceramic bearings [Re: cudaman1969] #3067096
08/11/22 03:04 PM
08/11/22 03:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You can see more here on the Microblue stuff
https://microbluebearings.com/
Re: Ceramic bearings [Re: Al_Alguire] #3067139
08/11/22 07:13 PM
08/11/22 07:13 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
Do the Dewco diff centers use ceramic bearing Al?
Alan Jones
Re: Ceramic bearings [Re: LA360] #3067155
08/11/22 07:56 PM
08/11/22 07:56 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
You can order them if you choose but IMO microblue is a better option.
Not sure I have ever shared this here but this is one of the centers from the Vette with Microblues in it
[video:youtube]https://www.youtube.com/shorts/TgtoIGrqAO8[/video]
Re: Ceramic bearings [Re: Al_Alguire] #3067241
08/12/22 03:52 AM
08/12/22 03:52 AM
LA360 Offline
LA360  Offline
I'm going try them out think
Alan Jones
Re: Ceramic bearings [Re: LA360] #3067298
08/12/22 10:43 AM
08/12/22 10:43 AM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Worth it? Depends on how much you are willing to pay for 1 MPH or 1 hundredth in a performance based class.
Several thousand to do front hubs and a complete rear end
Re: Ceramic bearings [Re: CMcAllister] #3067315
08/12/22 11:14 AM
08/12/22 11:14 AM
fredericksburg,va
fredericksburg,va
You just told me all I need to know, lol
Re: Ceramic bearings [Re: cudaman1969] #3067341
08/12/22 01:04 PM
08/12/22 01:04 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Microblues are SIGNIFICANTLY less money and pretty close in performance IMO.
Re: Ceramic bearings [Re: Al_Alguire] #3067384
08/12/22 03:39 PM
08/12/22 03:39 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
WOW
2011 Drag Pak Challenger
Re: Ceramic bearings [Re: Al_Alguire] #3067437
08/12/22 07:35 PM
08/12/22 07:35 PM
Man, that Ford nine inch turns over pretty easy now bow up work
Re: Ceramic bearings [Re: Al_Alguire] #3067455
08/12/22 08:12 PM
08/12/22 08:12 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Will check them out. Ceramics in the front wheels are amazing, but not cheap.
Re: Ceramic bearings [Re: CMcAllister] #3067536
08/13/22 07:45 AM
08/13/22 07:45 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
What kind of lube, if any, is used with ceramics?
'63 Dodge 330
11.19 @ 121 mph
Re: Ceramic bearings [Re: Cab_Burge] #3067607
08/13/22 12:23 PM
08/13/22 12:23 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Originally Posted by Cab_Burge
[/quote] Man, that Ford nine inch turns over pretty easy now bow up work
Cab thats actually a drop out 12 bolt center section. It goes in a 9" housing though. We channel our inner Comp racer as much as possible. Much less parasitic loss from the 12 bolt center but comes at a cost of weaker gears and not as many options ratio wise. In fact getting really hard to find pro gears these days. It also fits the Vettes tunnel which is quite small, not sure we could even fit a true 9" center in there without surgery. If anyone gets the chance to ever be at an NMCA or WCNA race we are at should check the car out. Most folks assume its some dumb Corvette guy with a scoop and chute on his 10 second Vette biggrin
Re: Ceramic bearings [Re: GY3] #3067609
08/13/22 12:29 PM
08/13/22 12:29 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
They are sealed bearings, think Mopar "green" bearings. I had them in a few of my cars.
But as pointed out ceramics are not cheap for sure. And at least for us not sure you will saw anything on the slip, but it rolls so much easier has to be something. But never heard of or seen anyone do any real A-B-A testing to prove any real gains,be difficult for sure. Honesty most guys have enough drag everywhere else not sure they need to worry about them. I mean if you have a ceramic front wheel bearing and your front brakes drag whats the point. I can tell you in Comp and Pro Stock they are used a lot as well as some of the SS and Stock guys.
Re: Ceramic bearings [Re: rickseeman] #3067613
08/13/22 12:43 PM
08/13/22 12:43 PM
So Cal
autoxcuda Offline
autoxcuda  Offline
So Cal
WOW
That's a FAT HEAVY Drag setup. laugh
The Circle Track ones eliminate ring gear bolts and the carriers are "windowed" and "bridged". Those are horsepower, car weight rules and track built specific of course.
