Re: Ceramic bearings
[Re: cudaman1969]
#3067091
08/11/22 02:47 PM
08/11/22 02:47 PM
Posts: 19,361 Las Vegas
Al_Alguire
Las Vegas
All of themI have used are ceramic ball bearings in a steel cage. Been using them for years and we have had some issues with pinion bearings...As for whether they are worth it or not that has something that has had mixed reviews from many. makes the car easier to push for sure but as for it showing in the slip, ehh...FWIW you can use a micro blue bearings which is also a very low drag bearing for much less money. We have gone to those for all the heavy load stuff for sure. At one point we had ceramics all over the car. Then they became much harder to get and since then the quality has not been the same. My understanding is the ceramic material is from overseas now.
[Re: LA360]
#3067155
08/11/22 07:56 PM
08/11/22 07:56 PM
Al_Alguire
Las Vegas
You can order them if you choose but IMO microblue is a better option. Not sure I have ever shared this here but this is one of the centers from the Vette with Microblues in it [video:youtube] https://www.youtube.com/shorts/TgtoIGrqAO8[/video]
[Re: LA360]
#3067298
08/12/22 10:43 AM
08/12/22 10:43 AM
Posts: 11,531 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Worth it? Depends on how much you are willing to pay for 1 MPH or 1 hundredth in a performance based class.
Several thousand to do front hubs and a complete rear end
[Re: CMcAllister]
#3067315
08/12/22 11:14 AM
08/12/22 11:14 AM
Posts: 8,237 fredericksburg,va
cudaman1969
fredericksburg,va
Several thousand to do front hubs and a complete rear end You just told me all I need to know, lol
[Re: cudaman1969]
#3067341
08/12/22 01:04 PM
08/12/22 01:04 PM
Al_Alguire
Las Vegas
Microblues are SIGNIFICANTLY less money and pretty close in performance IMO.
[Re: Al_Alguire]
#3067437
08/12/22 07:35 PM
08/12/22 07:35 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
You can order them if you choose but IMO microblue is a better option. Not sure I have ever shared this here but this is one of the centers from the Vette with Microblues in it [video:youtube] https://www.youtube.com/shorts/TgtoIGrqAO8[/video] Man, that Ford nine inch turns over pretty easy now
[Re: Al_Alguire]
#3067455
08/12/22 08:12 PM
08/12/22 08:12 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Microblues are SIGNIFICANTLY less money and pretty close in performance IMO. Will check them out. Ceramics in the front wheels are amazing, but not cheap.
[Re: CMcAllister]
#3067536
08/13/22 07:45 AM
08/13/22 07:45 AM
Posts: 4,669 Wichita
GY3
Wichita
What kind of lube, if any, is used with ceramics?
[Re: GY3]
#3067609
08/13/22 12:29 PM
08/13/22 12:29 PM
Al_Alguire
Las Vegas
What kind of lube, if any, is used with ceramics? They are sealed bearings, think Mopar "green" bearings. I had them in a few of my cars. But as pointed out ceramics are not cheap for sure. And at least for us not sure you will saw anything on the slip, but it rolls so much easier has to be something. But never heard of or seen anyone do any real A-B-A testing to prove any real gains,be difficult for sure. Honesty most guys have enough drag everywhere else not sure they need to worry about them. I mean if you have a ceramic front wheel bearing and your front brakes drag whats the point. I can tell you in Comp and Pro Stock they are used a lot as well as some of the SS and Stock guys.
[Re: rickseeman]
#3067613
08/13/22 12:43 PM
08/13/22 12:43 PM
Posts: 27,466 So Cal
autoxcuda
So Cal
You can order them if you choose but IMO microblue is a better option. Not sure I have ever shared this here but this is one of the centers from the Vette with Microblues in it [video:youtube] https://www.youtube.com/shorts/TgtoIGrqAO8[/video] WOW That's a FAT HEAVY Drag setup. The Circle Track ones eliminate ring gear bolts and the carriers are "windowed" and "bridged". Those are horsepower, car weight rules and track built specific of course.
