Re: Header bolts vs studs. Preferences?
[Re: dssaa]
#3066900
08/10/22 07:54 PM
08/10/22 07:54 PM
Posts: 271 Anchorage, Alaska
metallicareload
Anchorage, Alaska
What cylinder heads are you using? I’m using studs with aluminum heads, I guess cause studs are stock It does make installing the headers a little more difficult tho. As long as the actual mating surface is milled flat, there shouldn’t be any problems there. If I recall correctly, my tti’s were nicer than the Hedman’s I took off
440, 4-Speed, 3.54 1968, when Dinosaurs ruled the Earth
[Re: dssaa]
#3066924
08/10/22 08:39 PM
08/10/22 08:39 PM
Posts: 5,445 So Cal
Sinitro
So Cal
My preference is studs... Makes installing the gasket so much easier, just slide the gasket and header on, put the nuts and torque down. Just my $0.02...
[Re: dssaa]
#3066930
08/10/22 08:56 PM
08/10/22 08:56 PM
Posts: 2,652 Stuttgart, Arkansas
rickseeman
Stuttgart, Arkansas
are the mating surfaces supposed to look like a 2 year old did them? Mine seem flush, but the workmanship looks kind of amateur with uneven weld seams and marks. Is this common?
I assume those are made in China. When I called in June they said they are "in production". I said when will they be ready? He said last September. I'm sure the girl that made them was 12 not 2 though. Use studs wherever you can and bolts in the rest.
2011 Drag Pak Challenger
[Re: Cab_Burge]
#3066943
08/10/22 09:49 PM
08/10/22 09:49 PM
Posts: 977 Colorado
dssaa
Colorado
Got it! Thanks everyone. Hope to have it running again tomorrow!
[Re: topside]
#3066949
08/10/22 10:30 PM
08/10/22 10:30 PM
Posts: 18,157 Mass
DAYCLONA
Mass
Studs, definitely - especially anything that goes into coolant. Agreed....
[Re: dssaa]
#3066994
08/11/22 07:42 AM
08/11/22 07:42 AM
Posts: 744 Almost Heaven
Bob Stinson
Almost Heaven
Remember that part where I said I was afraid to snap off one of the studs......SON OF A B@&*^H! Front passengers side did not make it to 30ft lbs on the torque...snapped clean off. It was the last one I was torquing on the passengers side. Of Course. Sounds like my luck. I just installed a set of Schumacher shortys so I put studs in. One head had one stud in it so I left it alone but I knew it was going to be trouble. After putting in the other 11 studs and torqueing them, I went to put the nut on that pre-existing one and it just sort of fell out. I put a longer stud in it and it threaded in way past the shoulder and I couldn't torque it. Now I'm afraid to torque the nut because it doesn't seem to be getting tighter although the stud isn't turning. I figure I'm down to the last good thread in that hole and don't want to pull that one out too.
69 road runner A12 ex-racer 71 Duster w/ a 400
Shiny paint causes stress.
[Re: Bob Stinson]
#3067022
08/11/22 10:43 AM
08/11/22 10:43 AM
Posts: 15,416 Omaha Ne
TJP
Omaha Ne
i would just helicoil and move on. While I understand the concern of using using bolts in place of studs. I've bee doing do for 50 years without issue. I normally use a high temp sealer (copper or red). Using a wooden Q-tip I put a small amount in the threaded hole and on the end of the bolt, install and "elbow torque". Can't say I remember ever having an issue and if I did, drain the coolant, repeat the above on the offending bolt. Much easier than drilling out a broken stud in the car IMO Most headers I've seen over the years do not give enough clearance to use a regular sized nut and require the bolts with undersize heads
[Re: moparx]
#3067067
08/11/22 01:09 PM
08/11/22 01:09 PM
Posts: 8,290 fredericksburg,va
cudaman1969
fredericksburg,va
SBC stud kit hanging on the wall at the speed shop, stud 5/16” nuts were 7/16” hex & 1/4” thread with serrations on the back. They never got loose. Those nuts where great for tight spots too.
[Re: AndyF]
#3067376
08/12/22 03:04 PM
08/12/22 03:04 PM
Posts: 1,607 westerly, ri. usa
440lebaron
westerly, ri. usa
I use a combination of studs different length since they go into water jacket mr gasket makes a 3/8 stud with a 1/4/28 7/16 nut
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: 440lebaron]
#3067428
08/12/22 06:45 PM
08/12/22 06:45 PM
cudaman1969
fredericksburg,va
I use a combination of studs different length since they go into water jacket mr gasket makes a 3/8 stud with a 1/4/28 7/16 nut That’s the one I use
