Header bolts vs studs. Preferences? #3066895
08/10/22 07:29 PM
08/10/22 07:29 PM
Colorado
dssaa Online content OP
dssaa  Online Content OP
Colorado
Just got my TTI shorty headers for my 67 Charger/440. Still have the old threaded header studs in, but the TTI kit came with header bolts. What do ya think...take the old ones out and go with the header bolts? Which is better, or does it make no difference? I am sure getting the headers in minus the old threaded studs will be easier...but am scared to snap off one of the old ones getting them out. Also...for those of you who have installed the TTI's before....are the mating surfaces supposed to look like a 2 year old did them? Mine seem flush, but the workmanship looks kind of amateur with uneven weld seams and marks. Is this common? Hoping to get them loose fit tonight....
Dave in Colorado
Re: Header bolts vs studs. Preferences? [Re: dssaa] #3066900
08/10/22 07:54 PM
08/10/22 07:54 PM
Anchorage, Alaska
metallicareload Offline
Anchorage, Alaska
What cylinder heads are you using? I’m using studs with aluminum heads, I guess cause studs are stock shruggy It does make installing the headers a little more difficult tho. As long as the actual mating surface is milled flat, there shouldn’t be any problems there. If I recall correctly, my tti’s were nicer than the Hedman’s I took off
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
Re: Header bolts vs studs. Preferences? [Re: metallicareload] #3066907
08/10/22 08:17 PM
08/10/22 08:17 PM
Colorado
Colorado
Its currently running factory heads....
Re: Header bolts vs studs. Preferences? [Re: dssaa] #3066924
08/10/22 08:39 PM
08/10/22 08:39 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
My preference is studs...
Makes installing the gasket so much easier, just slide the gasket and header on, put the nuts and torque down.
Just my $0.02... wink
Re: Header bolts vs studs. Preferences? [Re: dssaa] #3066930
08/10/22 08:56 PM
08/10/22 08:56 PM
Stuttgart, Arkansas
rickseeman Offline
rickseeman  Offline
Stuttgart, Arkansas
I assume those are made in China. When I called in June they said they are "in production". I said when will they be ready? He said last September. I'm sure the girl that made them was 12 not 2 though.
Use studs wherever you can and bolts in the rest.
2011 Drag Pak Challenger
Re: Header bolts vs studs. Preferences? [Re: rickseeman] #3066936
08/10/22 09:21 PM
08/10/22 09:21 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Studs, definitely - especially anything that goes into coolant.
Re: Header bolts vs studs. Preferences? [Re: topside] #3066940
08/10/22 09:44 PM
08/10/22 09:44 PM
Colorado
Colorado
Studs it is. My only issue, and one that I had when I pulled the old headers off, is the as mentioned coolant. The header bolts that were in it were super short, and had silicone all over them (the rears had bolts, everything else is studs). The bolts in the TTI kit are a little longer, so hoping that helps. Should I still put some silicone RTV or a thread sealer on, or wait and see if it seals itself? Nothing worse than a coolant leak....
Re: Header bolts vs studs. Preferences? [Re: dssaa] #3066941
08/10/22 09:44 PM
08/10/22 09:44 PM
All 12 exhaust manifold holes are wet so you need to either use studs in every hole and bottom them out so coolant won't leak past the threads or use a good thread sealer on any header bolts you use up wrench
Most of the new aluminum heads have blind holes for the exhaust bolts, no sealer needed as they do not go into the water jacket in the heads work up grin
BTW, there may be one or up to 4 holes in those headers that need bolts instead of studs, seal them rascals up good wrench up
Re: Header bolts vs studs. Preferences? [Re: Cab_Burge] #3066943
08/10/22 09:49 PM
08/10/22 09:49 PM
Colorado
Colorado
Got it!
Thanks everyone. Hope to have it running again tomorrow!
Re: Header bolts vs studs. Preferences? [Re: dssaa] #3066947
08/10/22 10:23 PM
08/10/22 10:23 PM
Colorado
Colorado
Remember that part where I said I was afraid to snap off one of the studs......SON OF A B@&*^H! Front passengers side did not make it to 30ft lbs on the torque...snapped clean off. It was the last one I was torquing on the passengers side. Of Course.
Re: Header bolts vs studs. Preferences? [Re: topside] #3066949
08/10/22 10:30 PM
08/10/22 10:30 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Agreed....
Re: Header bolts vs studs. Preferences? [Re: dssaa] #3066994
08/11/22 07:42 AM
08/11/22 07:42 AM
Almost Heaven
Bob Stinson Offline
Bob Stinson  Offline
Almost Heaven
Sounds like my luck.
I just installed a set of Schumacher shortys so I put studs in. One head had one stud in it so I left it alone but I knew it was going to be trouble. After putting in the other 11 studs and torqueing them, I went to put the nut on that pre-existing one and it just sort of fell out. I put a longer stud in it and it threaded in way past the shoulder and I couldn't torque it. Now I'm afraid to torque the nut because it doesn't seem to be getting tighter although the stud isn't turning. I figure I'm down to the last good thread in that hole and don't want to pull that one out too.
69 road runner A12 ex-racer
71 Duster w/ a 400
Shiny paint causes stress.
Re: Header bolts vs studs. Preferences? [Re: dssaa] #3067002
08/11/22 08:21 AM
08/11/22 08:21 AM
Keymar, MD
DusterKid Offline
DusterKid  Offline
Keymar, MD
I prefer to use studs in places where I can. Sometimes the header design doesn't allow room to use a stud so than an bolt has to be used.
Re: Header bolts vs studs. Preferences? [Re: Bob Stinson] #3067022
08/11/22 10:43 AM
08/11/22 10:43 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
i would just helicoil and move on.
While I understand the concern of using using bolts in place of studs. I've bee doing do for 50 years without issue. I normally use a high temp sealer (copper or red). Using a wooden Q-tip I put a small amount in the threaded hole and on the end of the bolt, install and "elbow torque". Can't say I remember ever having an issue and if I did, drain the coolant, repeat the above on the offending bolt. Much easier than drilling out a broken stud in the car IMO
Most headers I've seen over the years do not give enough clearance to use a regular sized nut and require the bolts with undersize heads shruggy twocents beer
Re: Header bolts vs studs. Preferences? [Re: TJP] #3067057
08/11/22 12:33 PM
08/11/22 12:33 PM
moparx Offline
moparx  Offline
studs and using flange nuts with undersized hex here.
i just make sure i use the proper length stud for the intended header.
beer
Re: Header bolts vs studs. Preferences? [Re: moparx] #3067067
08/11/22 01:09 PM
08/11/22 01:09 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
SBC stud kit hanging on the wall at the speed shop, stud 5/16” nuts were 7/16” hex & 1/4” thread with serrations on the back. They never got loose. Those nuts where great for tight spots too.
Re: Header bolts vs studs. Preferences? [Re: dssaa] #3067158
08/11/22 07:58 PM
08/11/22 07:58 PM
AndyF Offline
AndyF  Offline
Always use studs if you can. Sometimes you can't.
Re: Header bolts vs studs. Preferences? [Re: AndyF] #3067376
08/12/22 03:04 PM
08/12/22 03:04 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
I use a combination of studs different length since they go into water jacket mr gasket makes a 3/8 stud with a 1/4/28 7/16 nut
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: Header bolts vs studs. Preferences? [Re: 440lebaron] #3067428
08/12/22 06:45 PM
08/12/22 06:45 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
That’s the one I use
