What cylinder heads are you using? I’m using studs with aluminum heads, I guess cause studs are stock shruggy It does make installing the headers a little more difficult tho. As long as the actual mating surface is milled flat, there shouldn’t be any problems there. If I recall correctly, my tti’s were nicer than the Hedman’s I took off
440, 4-Speed, 3.54
1968, when Dinosaurs ruled the Earth
