Help with part# for B body rubber firewall hole plug #3064804
08/03/22 12:20 AM
08/03/22 12:20 AM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
I "think" the part# is 2571069 but the numbers on the one original part I had were very worn.
www.DetroitMuscleTechnologies.com Mopar body and heater box restoration gaskets
Re: Help with part# for B body rubber firewall hole plug [Re: 71TA] #3065046
08/03/22 11:24 PM
08/03/22 11:24 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I use to have one of those No idea if I still have it or not
best I remember its 71 and up ????
Re: Help with part# for B body rubber firewall hole plug [Re: gtx6970] #3065400
08/05/22 08:57 AM
08/05/22 08:57 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What years does this plug fit?
Re: Help with part# for B body rubber firewall hole plug [Re: gtx6970] #3065401
08/05/22 08:58 AM
08/05/22 08:58 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
What years does that fit?
Re: Help with part# for B body rubber firewall hole plug [Re: 6PakBee] #3065457
08/05/22 12:21 PM
08/05/22 12:21 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The number suggests it was first produced for '64 models but might still be used many years after that.
Re: Help with part# for B body rubber firewall hole plug [Re: John_Kunkel] #3065531
08/05/22 04:55 PM
08/05/22 04:55 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Heres a discussion on Dodge Charger about these plugs. I THOUGHT they were used to fill the non AC heater box stud holes when an AC heater box was used.
http://www.dodgecharger.com/forum/index.php?topic=110012.0
Re: Help with part# for B body rubber firewall hole plug [Re: 71TA] #3065691
08/06/22 07:14 AM
08/06/22 07:14 AM
Abilene, Texas
fastmark Online content
fastmark  Online Content
Abilene, Texas
That’s what they are for. I’ve got a couple of ac b bodies at the shop. I’ll see what I can did up for you this morning at the shop.
Re: Help with part# for B body rubber firewall hole plug [Re: fastmark] #3066558
08/09/22 02:25 PM
08/09/22 02:25 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Thanks Mark
Re: Help with part# for B body rubber firewall hole plug [Re: 71TA] #3068091
08/15/22 09:36 AM
08/15/22 09:36 AM
Abilene, Texas
Abilene, Texas
Ok, I found a good one with a clear number still on it. Sorry for the delay, Jim. Yes, you have the correct part number on your first post.
Re: Help with part# for B body rubber firewall hole plug [Re: fastmark] #3068202
08/15/22 03:12 PM
08/15/22 03:12 PM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
I looked at my 67 over the weekend and it has a few of them it IS a factory air car .
BUT, they are NOT used to fill firewall holes for non air cars . Much to small for that and they not in the locations a non air box would mount
I will double ck this evening and see how many there are on it and locations and see if its also in both my 66's which are non air cars
Re: Help with part# for B body rubber firewall hole plug [Re: gtx6970] #3068278
08/15/22 08:39 PM
08/15/22 08:39 PM
Warren, MI
71TA Offline OP
71TA  Offline OP
Warren, MI
Thanks guys!
I was unsure of the part number because I can't find it in any of my parts manuals.
