727 transmission lines
#3063447
07/28/22 09:30 PM
07/28/22 09:30 PM
Posts: 459 las vegas,nv
mopar muscle7271
las vegas,nv
I have 72 duster with a 383 and 727 in it. Need some new transmission lines for it.Will ones from a 67-69 dart cuda that came with a 383 from factory work?since some had 383s in them from factory from 67-69.
Re: 727 transmission lines
[Re: mopar muscle7271]
#3063448
07/28/22 09:38 PM
07/28/22 09:38 PM
Posts: 3,087 Michigan
A727Tflite
I have 72 duster with a 383 and 727 in it. Need some new transmission lines for it.Will ones from a 67-69 dart cuda that came with a 383 from factory work?since some had 383s in them from factory from 67-69. I would imagine all A bodies would use the same cooler lines as long as it was equipped with a 727. Regardless of engine.
[Re: A727Tflite]
#3063555
07/29/22 11:15 AM
07/29/22 11:15 AM
Posts: 75,066 U.S.S.A.
JohnRR
U.S.S.A.
I have 72 duster with a 383 and 727 in it. Need some new transmission lines for it.Will ones from a 67-69 dart cuda that came with a 383 from factory work?since some had 383s in them from factory from 67-69. I would imagine all A bodies would use the same cooler lines as long as it was equipped with a 727. Regardless of engine. This ^^^^ ...a 727 is a 727 , big or smallblock, when it comes to cooler lines and linkage ... excluding hemi cars with extra external trans cooler . Just get lines for your car , 72 duster with a 727 ... 340's had them .
[Re: JohnRR]
#3063667
07/29/22 03:58 PM
07/29/22 03:58 PM
Posts: 27,471 So Cal
autoxcuda
So Cal
73-76 A-bodies take a different part number transmission lines. It's because of the Spool Mounts supports on the K-member.
So if you are using a DC Big Block K-member that uses a spool mount arrangement, I'd think you'd want a 73-76 A-body transmission line.
[Re: autoxcuda]
#3063684
07/29/22 04:23 PM
07/29/22 04:23 PM
mopar muscle7271
las vegas,nv
I'm using the 67-72 k-member biscuit type mounts with Schumacher engine mount conversion kit.
#3063703
07/29/22 06:14 PM
07/29/22 06:14 PM
autoxcuda
So Cal
I'm using the 67-72 k-member biscuit type mounts with Schumacher engine mount conversion kit. The 67-72 stuff should be good then.
