727 transmission lines #3063447
07/28/22 09:30 PM
07/28/22 09:30 PM
las vegas,nv
mopar muscle7271 Offline OP
las vegas,nv
I have 72 duster with a 383 and 727 in it. Need some new transmission lines for it.Will ones from a 67-69 dart cuda that came with a 383 from factory work?since some had 383s in them from factory from 67-69.
Re: 727 transmission lines [Re: mopar muscle7271] #3063448
07/28/22 09:38 PM
07/28/22 09:38 PM
A727Tflite Offline
A727Tflite  Offline
I would imagine all A bodies would use the same cooler lines as long as it was equipped with a 727.
Regardless of engine.
Re: 727 transmission lines [Re: A727Tflite] #3063488
07/29/22 01:59 AM
07/29/22 01:59 AM
las vegas,nv
las vegas,nv
Ok kinda what l though they work.lookin for advice by others see what they say before gettin
Re: 727 transmission lines [Re: A727Tflite] #3063555
07/29/22 11:15 AM
07/29/22 11:15 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
This ^^^^ ...a 727 is a 727 , big or smallblock, when it comes to cooler lines and linkage ... excluding hemi cars with extra external trans cooler .
Just get lines for your car , 72 duster with a 727 ... 340's had them .
Re: 727 transmission lines [Re: JohnRR] #3063667
07/29/22 03:58 PM
07/29/22 03:58 PM
So Cal
autoxcuda Online content
autoxcuda  Online Content
So Cal
73-76 A-bodies take a different part number transmission lines. It's because of the Spool Mounts supports on the K-member.
So if you are using a DC Big Block K-member that uses a spool mount arrangement, I'd think you'd want a 73-76 A-body transmission line.
Re: 727 transmission lines [Re: autoxcuda] #3063684
07/29/22 04:23 PM
07/29/22 04:23 PM
las vegas,nv
las vegas,nv
I'm using the 67-72 k-member biscuit type mounts with Schumacher engine mount conversion kit.
Re: 727 transmission lines [Re: mopar muscle7271] #3063703
07/29/22 06:14 PM
07/29/22 06:14 PM
So Cal
So Cal
The 67-72 stuff should be good then.
Re: 727 transmission lines [Re: autoxcuda] #3063786
07/30/22 03:36 AM
07/30/22 03:36 AM
las vegas,nv
las vegas,nv
Alright cool thanks for the info
