Clutch 10.5 or 11 #3059451
07/15/22 03:35 PM
07/15/22 03:35 PM
fury4speed Offline OP
I am going to change the clutch on my RB engine , new flywheel and new clutch kit , is a 11" clutch a simple bolt on as the flywheel has the hole for it so I want to know if everything else is a direct swap , thanks
Re: Clutch 10.5 or 11 [Re: fury4speed] #3059467
07/15/22 04:53 PM
07/15/22 04:53 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Not sure what this means
Tooth count has to match on the flywheels otherwise the bellhousing will not work with the new flywheel.
A 10.5" clutch usually has a 130 tooth flywheel, and the 11" one, assuming it's a true 11" and not the 10.95" one, has more teeth.
Re: Clutch 10.5 or 11 [Re: fury4speed] #3059468
07/15/22 04:57 PM
07/15/22 04:57 PM
If it is aftermarket replacement flywheel it may have both patterns on it, use the one that fits your pressure platewrench up scope
Don't forget to use the clutch disc alignment tool before tightening up the pressure plate bolts scope
Re: Clutch 10.5 or 11 [Re: Cab_Burge] #3062304
07/25/22 08:36 AM
07/25/22 08:36 AM
Cumming Georgia
cspracer Offline
cspracer  Offline
Cumming Georgia
Hey Cab,
I bought the wrong set-up for my car. Went with the 130 tooth flywheel and 10.5" clutch. Bought these a few years back from Summit and am now just getting it all together. The starter will not come close to engaging so after checking, my old one was indeed the 143 tooth and 11.0" clutch. If I want to use the new set-up, could I simply change the bellhousing? It may cost more to do this than to just buy the correct parts, but I hate to just put these on the shelf. Had them too long to ship back. What would you do?
1968 - 383 Roadrunner 4 speed street car, Dad bought new
1970 - 440 Roadrunner drag footbrake car 6.99 1/8th
2016 - Hemi RAM 1500 - Hauls all the toys
North Georgia / Central NC
Re: Clutch 10.5 or 11 [Re: cspracer] #3062344
07/25/22 10:24 AM
07/25/22 10:24 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Originally Posted by cspracer
Hey Cab,
I would try calling summit and see if they can exchange the flywheel or kit especially if it's still a current offering. they have been quite accommodating for me in situations like this beer
Re: Clutch 10.5 or 11 [Re: TJP] #3062347
07/25/22 10:30 AM
07/25/22 10:30 AM
IMGTX Offline
IMGTX  Offline
Hey Cab,
Good idea
If they can't help you can change the bellhousing but the bellcrank may be too short or may need a new mount.
Brewers or possably passion are good sources for the bellcrank/mounts and info.
Re: Clutch 10.5 or 11 [Re: IMGTX] #3062374
07/25/22 11:53 AM
07/25/22 11:53 AM
Moved to N.E. Tennessee
GomangoCuda Online work
GomangoCuda  Online Work
Hey Cab,
Good idea
You are going to need either an aftermarket 143 tooth flywheel that has both pressure plate bolt patterns or a bell housing for a 130 tooth flywheel. Brewers has both. Not a huge difference in price. Which ever way you go you may be able to sell yours on Moparts, eBay or Facebook.
Re: Clutch 10.5 or 11 [Re: GomangoCuda] #3062402
07/25/22 01:07 PM
07/25/22 01:07 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
LUK LFW106 is a 143 tooth flywheel that appears to have both patterns on it.
Under $100, less shipping and tax, from Rockauto
Re: Clutch 10.5 or 11 [Re: Sniper] #3062441
07/25/22 02:14 PM
07/25/22 02:14 PM
Cumming Georgia
cspracer Offline
cspracer  Offline
Cumming Georgia
Wow. Thanks, I will check that out!
Re: Clutch 10.5 or 11 [Re: cspracer] #3062483
07/25/22 03:43 PM
07/25/22 03:43 PM
Are you sure you want a cheap flywheel in between your body and the road work Not me tsk
Stay far, far away from any cast flywheels twocents
Re: Clutch 10.5 or 11 [Re: Sniper] #3062487
07/25/22 03:54 PM
07/25/22 03:54 PM
VA
dragon slayer Offline
VA
Is that internal or external balance FW? Interesting only listed for trucks.
Re: Clutch 10.5 or 11 [Re: dragon slayer] #3062491
07/25/22 04:12 PM
07/25/22 04:12 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Yes, I ran a flywheel in my Diplomat that was only listed for Dakotas. Same 130 tooth flywheel as the cars used. Lots of application issues these days, not just RA though, it usually the manufacturer. I did try to look it up at the LUK site, no help there.
As for a cast flywheel, isn't that what Chrysler put them? Some people think everything is a race car out there.
Re: Clutch 10.5 or 11 [Re: dragon slayer] #3062492
07/25/22 04:12 PM
07/25/22 04:12 PM
IMGTX Offline
IMGTX  Offline
It lists it as a flywheel for 318's so it should be internal balance.
As for why it is for trucks only is probably because only truck 318's got an 11" flywheel (143 tooth) during the years it is listed for. Passenger car 318's would be a 10.5" flywheel (130 tooth).
Re: Clutch 10.5 or 11 [Re: Sniper] #3062576
07/25/22 09:16 PM
07/25/22 09:16 PM
I'm under the impression from one of the old Mopar drag race seminars that all the production OEM flywheels for every V8 motor except the 1971 and later 360 where forged steel, not cast iron or cast steel confused
