Re: Clutch 10.5 or 11
[Re: fury4speed]
#3059468
07/15/22 04:57 PM
07/15/22 04:57 PM
Posts: 43,303 Bend,OR USA
Cab_Burge
[Re: Cab_Burge]
#3062304
07/25/22 08:36 AM
07/25/22 08:36 AM
Posts: 95 Cumming Georgia
cspracer
Cumming Georgia
Hey Cab,
I bought the wrong set-up for my car. Went with the 130 tooth flywheel and 10.5" clutch. Bought these a few years back from Summit and am now just getting it all together. The starter will not come close to engaging so after checking, my old one was indeed the 143 tooth and 11.0" clutch. If I want to use the new set-up, could I simply change the bellhousing? It may cost more to do this than to just buy the correct parts, but I hate to just put these on the shelf. Had them too long to ship back. What would you do?
1968 - 383 Roadrunner 4 speed street car, Dad bought new 1970 - 440 Roadrunner drag footbrake car 6.99 1/8th 2016 - Hemi RAM 1500 - Hauls all the toys North Georgia / Central NC
[Re: TJP]
#3062347
07/25/22 10:30 AM
07/25/22 10:30 AM
Posts: 12,245 Looking for a way out of Middl...
IMGTX
Hey Cab,
I bought the wrong set-up for my car. Went with the 130 tooth flywheel and 10.5" clutch. Bought these a few years back from Summit and am now just getting it all together. The starter will not come close to engaging so after checking, my old one was indeed the 143 tooth and 11.0" clutch. If I want to use the new set-up, could I simply change the bellhousing? It may cost more to do this than to just buy the correct parts, but I hate to just put these on the shelf. Had them too long to ship back. What would you do? I would try calling summit and see if they can exchange the flywheel or kit especially if it's still a current offering. they have been quite accommodating for me in situations like this Good idea If they can't help you can change the bellhousing but the bellcrank may be too short or may need a new mount. Brewers or possably passion are good sources for the bellcrank/mounts and info.
[Re: IMGTX]
#3062374
07/25/22 11:53 AM
07/25/22 11:53 AM
Posts: 4,760 Moved to N.E. Tennessee
GomangoCuda
Hey Cab,
I bought the wrong set-up for my car. Went with the 130 tooth flywheel and 10.5" clutch. Bought these a few years back from Summit and am now just getting it all together. The starter will not come close to engaging so after checking, my old one was indeed the 143 tooth and 11.0" clutch. If I want to use the new set-up, could I simply change the bellhousing? It may cost more to do this than to just buy the correct parts, but I hate to just put these on the shelf. Had them too long to ship back. What would you do? I would try calling summit and see if they can exchange the flywheel or kit especially if it's still a current offering. they have been quite accommodating for me in situations like this Good idea If they can't help you can change the bellhousing but the bellcrank may be too short or may need a new mount. Brewers or possably passion are good sources for the bellcrank/mounts and info. You are going to need either an aftermarket 143 tooth flywheel that has both pressure plate bolt patterns or a bell housing for a 130 tooth flywheel. Brewers has both. Not a huge difference in price. Which ever way you go you may be able to sell yours on Moparts, eBay or Facebook.
[Re: Sniper]
#3062441
07/25/22 02:14 PM
07/25/22 02:14 PM
cspracer
Cumming Georgia
Wow. Thanks, I will check that out!
[Re: cspracer]
#3062483
07/25/22 03:43 PM
07/25/22 03:43 PM
Cab_Burge
Wow. Thanks, I will check that out! Are you sure you want a cheap flywheel in between your body and the road ![work work](/ubbthreads/images/graemlins/custom/work.gif) Not me ![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif) Stay far, far away from any cast flywheels ![twocents twocents](/ubbthreads/images/graemlins/custom/twocents.gif)
[Re: Sniper]
#3062487
07/25/22 03:54 PM
07/25/22 03:54 PM
Posts: 1,340 VA
dragon slayer
VA
LUK LFW106 is a 143 tooth flywheel that appears to have both patterns on it.
Under $100, less shipping and tax, from Rockauto Is that internal or external balance FW? Interesting only listed for trucks.
[Re: dragon slayer]
#3062491
07/25/22 04:12 PM
07/25/22 04:12 PM
Posts: 6,324 nowhere
Sniper
nowhere
Under $100, less shipping and tax, from Rockauto Is that internal or external balance FW? Interesting only listed for trucks. Yes, I ran a flywheel in my Diplomat that was only listed for Dakotas. Same 130 tooth flywheel as the cars used. Lots of application issues these days, not just RA though, it usually the manufacturer. I did try to look it up at the LUK site, no help there. As for a cast flywheel, isn't that what Chrysler put them? Some people think everything is a race car out there.
