Hughes torque converters #3058091
07/11/22 12:07 AM
07/11/22 12:07 AM
houston texas
gremlinsteve Offline OP
houston texas
Any one have experiance with the brand
I know there decent with other items but I’ve got a new 2500 stall converter (440 based)
That I wanna use
Good or should I go elsewhere. This is not. Race car
Just a mild street car I’m using it for
I want a stable idle and don’t want the car to push through the brakes like this stock converter is trying to do
if You Like Gremlinsteve. Gremlinsteve Likes You.
Re: Hughes torque converters [Re: gremlinsteve] #3058132
07/11/22 08:45 AM
07/11/22 08:45 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
I’m using their 24-25 HD that I put in last year behind my @9.6cr 440-6 3.55 8 3/4…runs good👍
Re: Hughes torque converters [Re: shakerjoe] #3058173
07/11/22 10:59 AM
07/11/22 10:59 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
I've got a 3500 stall 904 unit. It worked good for me. I'm putting that engine/trans in a street car and that's a little too high for my liking on the street. I was looking around at Summit Racing for a Hughes 2000-2500 stall and found out that they now charge a $100 core for all their converters. I didn't see that any other converter manufacture was doing that.
Re: Hughes torque converters [Re: burdar] #3058192
07/11/22 12:02 PM
07/11/22 12:02 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I bet used cores are almost impossible to find. A budget 2000 - 2500 like you are looking for is probably made from a stock converter. How many of those could still be around? Spend 2 or 3 times as much for a good converter that is made for your application and you will be much happier. You CAN have both higher stall AND far less slippage in a good modern converter. Better performance and better drivability at the same time. Win Win.
Re: Hughes torque converters [Re: gremlinsteve] #3058212
07/11/22 12:36 PM
07/11/22 12:36 PM
Rancho Cordova, CA
Exit1965 Offline
Exit1965  Offline
Rancho Cordova, CA
I've run one before, a 3000 stall. Worked great. It sounds like the right fit for what you want, and you have it. Absolutely no reason not to run it.
Re: Hughes torque converters [Re: Exit1965] #3058222
07/11/22 01:07 PM
07/11/22 01:07 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I put one in a diesel and it was made with a defect. It chewed the edge off the lockup clutch. They wouldn’t do anything for me. No call tag , no payback for any of the trouble once they had it in hand and acknowledged it was a manufacturer error. No new one to stick in to keep the truck from being down. The trans shop didn’t have room to leave it undone. Best they would do after the fact was a convertor “at cost” after I complained at the mess being mishandled.
I had to have the truck back and a stock reman went in while this mess unfolded. I wanted to keep using a better converter, but to this day the truck isn’t as good as it could be thanks to them not sending me one to stick in as the junk one came out. I told them that was it for them getting my money or recommendation to anyone. They will leave you hanging.
I want my fair share
Re: Hughes torque converters [Re: gremlinsteve] #3058258
07/11/22 02:23 PM
07/11/22 02:23 PM
Guitar Jones Offline
I am not a fan.
Re: Hughes torque converters [Re: Guitar Jones] #3058321
07/11/22 05:14 PM
07/11/22 05:14 PM
houston texas
houston texas
Originally Posted by Guitar Jones
I am not a fan.
Any particular reason
Re: Hughes torque converters [Re: gremlinsteve] #3058343
07/11/22 06:07 PM
07/11/22 06:07 PM
Cab_Burge Online work
Cab_Burge  Online Work
I am not a fan.
l know lots of NHRA class racers bought and tried them back in the 1980s when they first opened and started making and selling converters, not many where happy with them shruggy work
Hi Po and race Converters have a really big need for highly skill machine work and tolerances being built, not every shop can do that time after time work
i have never bought or use one of theirs based on that, maybe their good on some other brands beside Mopar converters confused work
Re: Hughes torque converters [Re: GomangoCuda] #3058410
07/11/22 10:08 PM
07/11/22 10:08 PM
oklahoma
forphorty Offline
forphorty  Offline
oklahoma
this
Re: Hughes torque converters [Re: forphorty] #3058417
07/11/22 10:28 PM
07/11/22 10:28 PM
houston texas
houston texas
Good points
Re: Hughes torque converters [Re: gremlinsteve] #3058421
07/11/22 10:32 PM
07/11/22 10:32 PM
I am not a fan.
I bought a converter from them. Their total recomendation. I never thought the car ran as strong as it should have. Called Paul Forte, got his recommended converter and the car picked up 7 tenths. I had that converter freshened and tweaked by FTI and I was also very happy with them.
Re: Hughes torque converters [Re: Guitar Jones] #3058423
07/11/22 10:35 PM
07/11/22 10:35 PM
houston texas
houston texas
Seven tenths. That’s incredible
I’ve heard of Fri also
Re: Hughes torque converters [Re: gremlinsteve] #3058616
07/12/22 03:29 PM
07/12/22 03:29 PM
moparx Offline
moparx  Offline
reminds me of the GER brand.........................
beer
Re: Hughes torque converters [Re: moparx] #3058644
07/12/22 05:20 PM
07/12/22 05:20 PM
God's Country Maryland
GODSCOUNTRY340 Offline
beer
OMG, those GER converters were total pieces of SH$T.
Re: Hughes torque converters [Re: GODSCOUNTRY340] #3058662
07/12/22 06:51 PM
07/12/22 06:51 PM
houston texas
houston texas
Ger
Man I even knew better than to use them
How many decades ago where they in biz?
Re: Hughes torque converters [Re: gremlinsteve] #3058686
07/12/22 07:54 PM
07/12/22 07:54 PM
The late 1970s up to the mid to late 1980s, I made the mistake of buying one and trying to use it whiney It was horrible realcrazy
Sent to a local good converter guy in SO CA and he fixed perfectly boogie
I, we, (I was helping Steve and Linda Myers) started NHRA drag racing in NHRA "stock" class in 1973, we approach Art Carr and several other converter and tranny companies in SO CA for a full or partial sponsorship.
Art made us a deal on sponsoring us on the tranny maintenance for that year (1973 or 1974, CRS) if we bought one of his 8-inch race converters. That converter was .3 to .4 ET slower than the stock 11 inch Street Hemi converter and 3 to 4 MPH slower in the 1/4 mile also, what a piece of Shitt down
We messed around with him for a full year on that converter and finally bought a Rossi converter and picked up near .5 ET and most of the lost MPH from the stock converter wrench up
I ended up buying a GER for a friend for his SB and testing in one my BB bracket cars, it was no good, ended up taking it to Munsiger and he fixed up good boogie up
My message is buy the best converter you can get, not any of the cheaper ones tsk
Re: Hughes torque converters [Re: Cab_Burge] #3058724
07/12/22 10:14 PM
07/12/22 10:14 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
My cousin and I both had GER converters in our Buicks in the early 80s. We had good luck.
I used one in Trans Am I built for a buddy in 92. It was junk. I think they went under about then.
Now I used Coan, PTC or ATI.
Re: Hughes torque converters [Re: slantzilla] #3058750
07/13/22 01:53 AM
07/13/22 01:53 AM
Shopping @ HoBo Fright
340SIX Offline
Doc Flappergas's Evil Twin
340SIX  Offline
I am running an old Fairbanks, biught new back in mid 80 Modified Hemi freshener her up by Turbo Action. Never a problem.
I sent my J Converter to Turbo Action and had it freashened too. But have not run it yet.
Their reverse vavle body works. Did good steels, clutches, a and lots of billet.
But think good parts,are worth it in the long run
[img]https://i234.photobucket.com/albums/ee87/fast340six/sig%20pics/2840886-340SIX-1.jpg[/img]
VP of the MPM in New Orleans
73 Dart Sport 340/ 70 challenger vert. That may still get built, If I live long enough
Re: Hughes torque converters [Re: 340SIX] #3059209
07/14/22 02:30 PM
07/14/22 02:30 PM
houston texas
houston texas
It’s already looking bad
I decided to purchase the Hughes converter
In a 2400-2500 stall speed
Nothing special
It got shipped quickly and delivered on time
Problems arose when I picked it up (box) the
Converter was just sitting loosely in the box
It had no packing material ect. Just rolling around ect…
I checked it out good. Doesn’t appear to be pre owned in any way
But hell who knows
