Specs for oil pressure sensors? #3057429
07/08/22 02:46 PM
07/08/22 02:46 PM
BDW Offline OP
BDW  Offline OP
I'd like to find a newer/different oil pressure sensor for a 5.7 swap.
2 reasons for this, the old PS59 sensor is large and requires multiple adapters.
Ideally there would be a different sensor with smaller body and same resistance range.
Problem is, none of the sites give resistance info for the sensors.
Old sensor is 1.8" NPT, and the 5.7 block needs a 1/4" NPT.
Long winded explanation to ask, how can I find the resistance specs on a new car sensor?
Re: Specs for oil pressure sensors? [Re: BDW] #3057434
07/08/22 02:52 PM
07/08/22 02:52 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The sensor is going to be dependent on what you are using for a gauge cluster. If old original just use the compatible sensor and get a 1/8 npt to 3/8 npt adapter.
Re: Specs for oil pressure sensors? [Re: BDW] #3057436
07/08/22 02:56 PM
07/08/22 02:56 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Ohm range:
74= Full scale
23= Half scale
10= Bottom scale
Some replacement parts catalogs list the resistance.
Re: Specs for oil pressure sensors? [Re: BDW] #3057440
07/08/22 03:19 PM
07/08/22 03:19 PM
Cranberry Twp PA (North of Pit...
rumblefish72 Offline
Look to see if you can find a "datasheet" for the part# on the manufacturer's website.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
Re: Specs for oil pressure sensors? [Re: rumblefish72] #3057452
07/08/22 04:30 PM
07/08/22 04:30 PM
BDW Offline OP
BDW  Offline OP
That's the problem, no info on site, not even the thread size of the sensors, so definitely no resistance info.
Re: Specs for oil pressure sensors? [Re: BDW] #3057460
07/08/22 05:38 PM
07/08/22 05:38 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Didn't we just do this?
https://board.moparts.org/ubbthread...th-93-cluster-74-sender.html#Post3054580
What gauge are you using?
That will determine what specifications your sender needs to have.
If you are using the older musclecar era type gauge then the specs Kunkel gave you are correct, just use an adapter.
If you are using a later model gauge then all I can suggest is THIS they list specs. not sure if it will help.
Re: Specs for oil pressure sensors? [Re: John_Kunkel] #3057474
07/08/22 07:04 PM
07/08/22 07:04 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Originally Posted by John_Kunkel
Ohm range:
74= Full scale
23= Half scale
10= Bottom scale
Note that in order to calibrate the meter, it is possible to add or decrease the ohms by adding external resistors...
Just my $0.02... wink
Re: Specs for oil pressure sensors? [Re: Sinitro] #3057505
07/08/22 09:02 PM
07/08/22 09:02 PM
BDW Offline OP
BDW  Offline OP
Sorry , here’s the rest of the info.
Need oil pressure sensor to work with 70 ralley gauges.
The old pressure sensor has a large can body.
This large can won’t fit on the 5.7 Hemi because the alternator occupies the same area.
A smaller sensor, there’s another just below it, would fit.
The other option is to add at least 2 adapters, 1/8” to 1/4” and a 90 degree to point it rearward.
Was hoping to find something to screw directly in.
Re: Specs for oil pressure sensors? [Re: BDW] #3057510
07/08/22 09:14 PM
07/08/22 09:14 PM
Cab_Burge Online work
Cab_Burge  Online Work
How about drilling and tapping it in another place to make the new type sender work for you work scope wrench up
I am now using the big remote NASCAR Wix brand race filters on all my drag race motors up wrench
I drill and tap them in two places for the electric oil temp and oil pressure senders up scope
Re: Specs for oil pressure sensors? [Re: BDW] #3057535
07/08/22 10:15 PM
07/08/22 10:15 PM
N
NITROUSN Offline
NITROUSN  Offline
N
Why not get a braided ss flex line and mount it remotely?
Re: Specs for oil pressure sensors? [Re: NITROUSN] #3057540
07/08/22 10:22 PM
07/08/22 10:22 PM
Freeport IL USA
poorboy Offline
poorboy  Offline
Freeport IL USA
Yes, nothing says the sensor has to be mounted on the motor, there may be a few milliseconds before the gauge sees the response, but if your using the old 70s gauges, a few milliseconds won't make much difference. Just be sure the sender is secure where ever and how ever its mounted.
Re: Specs for oil pressure sensors? [Re: BDW] #3057644
07/09/22 12:11 PM
07/09/22 12:11 PM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
I used the 1/8" npt port on the front of the engine. used the same type of sending unit.
