Re: Specs for oil pressure sensors?
[Re: BDW]
#3057436
07/08/22 02:56 PM
07/08/22 02:56 PM
Posts: 25,748 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Ohm range:
74= Full scale
23= Half scale
10= Bottom scale
Some replacement parts catalogs list the resistance.
[Re: BDW]
#3057440
07/08/22 03:19 PM
07/08/22 03:19 PM
Posts: 246 Cranberry Twp PA (North of Pit...
rumblefish72
Look to see if you can find a "datasheet" for the part# on the manufacturer's website.
1972 Pro-Street 'Cuda, 500" Eagle stoker B Block, Eddy RPM heads, Victor Manifold, 850 Mighty Demon, Hemi 4 Speed, Dana 60 w/4.88 gears - Built by Hansen Racing Middlesex - NJ
[Re: rumblefish72]
#3057452
07/08/22 04:30 PM
07/08/22 04:30 PM
Posts: 4,707 Florida
BDW
Look to see if you can find a "datasheet" for the part# on the manufacturer's website. That's the problem, no info on site, not even the thread size of the sensors, so definitely no resistance info.
[Re: BDW]
#3057460
07/08/22 05:38 PM
07/08/22 05:38 PM
Posts: 6,225 nowhere
Sniper
nowhere
Didn't we just do this? https://board.moparts.org/ubbthread...th-93-cluster-74-sender.html#Post3054580What gauge are you using? That will determine what specifications your sender needs to have. If you are using the older musclecar era type gauge then the specs Kunkel gave you are correct, just use an adapter. If you are using a later model gauge then all I can suggest is THIS they list specs. not sure if it will help.
[Re: John_Kunkel]
#3057474
07/08/22 07:04 PM
07/08/22 07:04 PM
Posts: 5,439 So Cal
Sinitro
So Cal
Ohm range:
74= Full scale
23= Half scale
10= Bottom scale
Some replacement parts catalogs list the resistance. Note that in order to calibrate the meter, it is possible to add or decrease the ohms by adding external resistors... Just my $0.02...
[Re: BDW]
#3057510
07/08/22 09:14 PM
07/08/22 09:14 PM
Posts: 43,126 Bend,OR USA
Cab_Burge
[Re: BDW]
#3057535
07/08/22 10:15 PM
07/08/22 10:15 PM
Posts: 18,408 UPPER MICHIGAN, MARQUETTE COUN...
NITROUSN
Sorry , here’s the rest of the info. Need oil pressure sensor to work with 70 ralley gauges. The old pressure sensor has a large can body. This large can won’t fit on the 5.7 Hemi because the alternator occupies the same area. A smaller sensor, there’s another just below it, would fit. The other option is to add at least 2 adapters, 1/8” to 1/4” and a 90 degree to point it rearward. Was hoping to find something to screw directly in. Why not get a braided ss flex line and mount it remotely?
