Radiator hose clamps #3054045
06/28/22 09:24 AM
06/28/22 09:24 AM
Virginia
BSharp Offline OP
BSharp  Offline OP
Virginia
Yes, the exciting world of hose clamps. I used modern-style spring clamps when starting a fresh engine and had two radiator hose leaks. One on a very smooth aluminum radiator inlet, and one on a rougher thermostat housing. Just not enough clamping force. I fixed both with a couple of junky worm-drive clamps, but I'd like to put on some nicer stainless ones. What do you like?
Re: Radiator hose clamps [Re: BSharp] #3054101
06/28/22 01:51 PM
06/28/22 01:51 PM
New, shiny screw clamps twocents up
Re: Radiator hose clamps [Re: Cab_Burge] #3054135
06/28/22 04:08 PM
06/28/22 04:08 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've had that 1 time on a restoration; another restoration clamp with more clamping tension fixed it.
My thing:
Restorations = correct clamps.
Hot rods & racecars = worm drive clamps.
Lots of old road course racecars use double clamps.
Re: Radiator hose clamps [Re: topside] #3054157
06/28/22 05:10 PM
06/28/22 05:10 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
Constant tension hose clamps.
Re: Radiator hose clamps [Re: topside] #3054207
06/28/22 09:09 PM
06/28/22 09:09 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
My thing:
restoration: have to source QUALITY clamps from AMK or equivalent. most of the CRA- that classic sells is just that
or worm drive, if you want pretty get SS and polish them twocents beer
Re: Radiator hose clamps [Re: TJP] #3054268
06/29/22 06:47 AM
06/29/22 06:47 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
Quote
If it's a hard to get to location these. up
Re: Radiator hose clamps [Re: BSharp] #3054276
06/29/22 07:42 AM
06/29/22 07:42 AM
MD
RTSE4ME Offline
RTSE4ME  Offline
MD
worm drive clamps. and heat shrink hose clamps
Re: Radiator hose clamps [Re: RTSE4ME] #3054289
06/29/22 09:02 AM
06/29/22 09:02 AM
Virginia
BSharp Offline OP
BSharp  Offline OP
Virginia
Thanks for the input.
I'm looking at worm-drive clamps from Gates (they should know how to clamp a hose, right?). These for silicone have a smooth inner band to protect the soft hose; is there any reason they couldn't be used on rubber? They also have the perforated version for firm rubber. They're both about the same price at two or three times the store brands, but leaks are annoying enough to justify it.
The heat-shrink clamps are interesting, but they're single-use and look like it would be hard to remove them without damaging the hose.
Re: Radiator hose clamps [Re: BSharp] #3054294
06/29/22 09:20 AM
06/29/22 09:20 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
I use the heat shrink clamps on mine. They are awesome and give a clean look.
https://www.gates.com/gb/en/fluid-p...-and-couplings.p.7405-000000-000000.html
'63 Dodge 330
11.19 @ 121 mph
Re: Radiator hose clamps [Re: BSharp] #3054301
06/29/22 09:43 AM
06/29/22 09:43 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
I usually buy Tridon, breeze or other brand including house brands wit no problems wink
Re: Radiator hose clamps [Re: TJP] #3054320
06/29/22 10:31 AM
06/29/22 10:31 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
My cars are stock restored .
I have used the stock corbin clamps always,,,,, and never a problem, BUT ,, I try my best to not reuse them if I can get away with it. Its nIce to have a stock of them from when I carried them
Re: Radiator hose clamps [Re: gtx6970] #3054322
06/29/22 10:33 AM
06/29/22 10:33 AM
It's a dry heat
gtx6970 Offline
gtx6970  Offline
It's a dry heat
PS, the source if you want to buy in bulk , https://www.rotorclip.com/ https://www.rotorclip.com/cat_pdfs/hc.pdf
I can go thru my stash and get the part number for mopar stuff if needed
As an example.
The correct one for the power brake booster hose is HC11 and is red zinc plated
Re: Radiator hose clamps [Re: BSharp] #3054468
06/29/22 05:44 PM
06/29/22 05:44 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
The perforated clamps will dig into the rubber and chew it up to some extent.
You can use the smooth ones though, I prefer them to perforated ones even on the constant tension ones.
