Re: Radiator hose clamps
[Re: RTSE4ME]
#3054289
06/29/22 09:02 AM
06/29/22 09:02 AM
Posts: 4,877 Virginia
BSharp
Virginia
Thanks for the input. I'm looking at worm-drive clamps from Gates (they should know how to clamp a hose, right?). These for silicone have a smooth inner band to protect the soft hose; is there any reason they couldn't be used on rubber? They also have the perforated version for firm rubber. They're both about the same price at two or three times the store brands, but leaks are annoying enough to justify it. The heat-shrink clamps are interesting, but they're single-use and look like it would be hard to remove them without damaging the hose.
[Re: BSharp]
#3054301
06/29/22 09:43 AM
06/29/22 09:43 AM
Posts: 15,358 Omaha Ne
TJP
Omaha Ne
Thanks for the input. I'm looking at worm-drive clamps from Gates (they should know how to clamp a hose, right?). These for silicone have a smooth inner band to protect the soft hose; is there any reason they couldn't be used on rubber? They also have the perforated version for firm rubber. They're both about the same price at two or three times the store brands, but leaks are annoying enough to justify it. The heat-shrink clamps are interesting, but they're single-use and look like it would be hard to remove them without damaging the hose. I usually buy Tridon, breeze or other brand including house brands wit no problems
[Re: TJP]
#3054320
06/29/22 10:31 AM
06/29/22 10:31 AM
Posts: 21,429 It's a dry heat
gtx6970
It's a dry heat
My cars are stock restored . I have used the stock corbin clamps always,,,,, and never a problem, BUT ,, I try my best to not reuse them if I can get away with it. Its nIce to have a stock of them from when I carried them
[Re: BSharp]
#3054468
06/29/22 05:44 PM
06/29/22 05:44 PM
Posts: 6,250 nowhere
Sniper
nowhere
Thanks for the input. I'm looking at worm-drive clamps from Gates (they should know how to clamp a hose, right?). These for silicone have a smooth inner band to protect the soft hose; is there any reason they couldn't be used on rubber? They also have the perforated version for firm rubber. They're both about the same price at two or three times the store brands, but leaks are annoying enough to justify it. The heat-shrink clamps are interesting, but they're single-use and look like it would be hard to remove them without damaging the hose. The perforated clamps will dig into the rubber and chew it up to some extent. You can use the smooth ones though, I prefer them to perforated ones even on the constant tension ones.
