Who has milled their Stealths? #305372
05/02/09 10:36 AM
05/02/09 10:36 AM
San Gabriel, CA 91775
rexus31 Offline OP
rexus31  Offline OP
How much did you take off? What is your compression ratio? Chamber volume?
As it stands right now, if I bolt my Stealths on my 383 (.030 over, slug .035 in the hole) I'm at 8.8:1. This is basically a stock spec street motor with a .450 lift cam; very mild. I got the Stealths becasue of their affordability and close resemblance to a stock casting more so than their added performance. I'm just wondering if I should mill them or run them as is.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue 1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red 1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red "What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Who has milled their Stealths? [Re: rexus31] #305373
05/02/09 10:45 AM
05/02/09 10:45 AM
chicago il usa
K
komninon Offline
komninon  Offline
K
chicago il usa
my motor is still at the machine shop. is a 440 with stealth heads. i think they milled the heads .050 use fel -pro 1105 gaskets
now it is 78cc and compression 10.6 to 1. i will have all the paperwork next week after the dyno.
Re: Who has milled their Stealths? [Re: komninon] #305374
05/02/09 01:19 PM
05/02/09 01:19 PM
Renton, Wa.
Classof70Chally Offline
super gas
super gas
Renton, Wa.
I left mine unmilled for a 84cc chamber (confirmed). This with my pistons at zero deck and a .045 gasket gives me a CR of 10.0 to 1 which is what I was shooting for with my cam combo and pump swill.
Re: Who has milled their Stealths? [Re: komninon] #305375
05/02/09 01:35 PM
05/02/09 01:35 PM
rexus31 Offline OP
rexus31  Offline OP
Thanks. What gas are you planning to use?
Re: Who has milled their Stealths? [Re: rexus31] #305376
05/02/09 09:45 PM
05/02/09 09:45 PM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
Milled .075 started at 84 cc now 72 cc. We had to take .095 o9ff the intake side.I would take half of the head and then the rest off the intake manifold,
If the MODS did their job I would not be hitting the notify MOD button. LOL
Re: Who has milled their Stealths? [Re: rexus31] #305377
05/02/09 10:52 PM
05/02/09 10:52 PM
chicago il usa
K
komninon Offline
komninon  Offline
K
chicago il usa
i would use 93 octane .
Re: Who has milled their Stealths? [Re: slippery440] #305378
05/02/09 10:54 PM
05/02/09 10:54 PM
rexus31 Offline OP
rexus31  Offline OP
Wow....using a web based milling calculator, it would only take .040 to get them down to 72cc. Based on my calculations, milling them .075 would give you 62cc chambers. What's your compression ratio? 440 or 383?
Re: Who has milled their Stealths? [Re: rexus31] #305379
05/02/09 10:57 PM
05/02/09 10:57 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
Was that calculator based on a typical Mopar chamber? cause the Stealths taper quite a bit more than say a 915..
Re: Who has milled their Stealths? [Re: 1_WILD_RT] #305380
05/02/09 11:11 PM
05/02/09 11:11 PM
rexus31 Offline OP
rexus31  Offline OP
Does that mean more material has to be removed to obtain a certain chamber volume?
Re: Who has milled their Stealths? [Re: rexus31] #305381
05/02/09 11:14 PM
05/02/09 11:14 PM
Today? Who Knows?
1_WILD_RT Offline
Management Trainee
1_WILD_RT  Offline
Management Trainee
Today? Who Knows?
I think do to the chamber shape the first .025 would probably be more cc's than a std head but by .035 you'd need to take more material to get the same effect... BTW This is just a guess based on my visual impression of the chamber shape..
Re: Who has milled their Stealths? [Re: 1_WILD_RT] #305382
05/03/09 03:16 AM
05/03/09 03:16 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
cc'd mine at 86/7.milled down for 78cc
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Who has milled their Stealths? [Re: tex013] #305383
05/03/09 08:44 AM
05/03/09 08:44 AM
southwest Alabama
challenger73400 Offline
southwest Alabama
milled mine .075" and got 72cc for 12:1 w/flat tops
Re: Who has milled their Stealths? [Re: tex013] #305384
05/03/09 08:47 AM
05/03/09 08:47 AM
Central New York
slippery440 Offline
Crybaby440
slippery440  Offline
Crybaby440
Central New York
We cc the head 3 times. Once before and then at .045 and then at .075. Kind of suprised me too.We figure about 11.5 or 12 to 1 compression.Block at zero and flat top pistons at .005 out.
Re: Who has milled their Stealths? [Re: rexus31] #305385
05/03/09 09:43 AM
05/03/09 09:43 AM
NC
440Jim Online work
440Jim  Online Work
NC
I would do something to get the CR up higher, unless you insist on running 87 octane. A piston to get zero deck would have been the best choice, but you have to do with what you got. IMO, a 10.0 CR, aluminum head, mild perf cam should be able to run on 92 octane or less.
Re: Who has milled their Stealths? [Re: rexus31] #305386
05/04/09 11:50 AM
05/04/09 11:50 AM
organ
maximum entropy Offline
organ
i got a set of the cnc stealths. the chambers were all over the place- 83 to 85.5. i equalised them at 85.5 and had them milled .040 and they measured 76 cc if i remember.
Re: Who has milled their Stealths? [Re: maximum entropy] #305387
05/04/09 12:24 PM
05/04/09 12:24 PM
rexus31 Offline OP
rexus31  Offline OP
Did you have to shave the intake? How much did it cost you to have the heads milled?
Re: Who has milled their Stealths? [Re: rexus31] #305388
05/04/09 01:31 PM
05/04/09 01:31 PM
organ
organ
the machinist i took it to charged me about 70.00. he said he prefers to shave the intake only, to compensate, not the intake side of the heads. not the way i would do it, but, hey, making your machinist irritated seems like a really bad idea, you know?
Re: Who has milled their Stealths? [Re: maximum entropy] #305389
05/04/09 03:39 PM
05/04/09 03:39 PM
rexus31 Offline OP
rexus31  Offline OP
How much did he take off the intake?
Re: Who has milled their Stealths? [Re: rexus31] #305390
05/04/09 04:45 PM
05/04/09 04:45 PM
organ
organ
he didn't take any off of the intake face of the heads, and i haven't mocked up the intake yet- it'll be a couple of weeks. the block was decked .025, btw. i can pm you with the results, if you like?
Re: Who has milled their Stealths? [Re: maximum entropy] #305391
05/04/09 09:57 PM
05/04/09 09:57 PM
rexus31 Offline OP
rexus31  Offline OP
That would be great, thanks!
