Who has milled their Stealths?
#305372
05/02/09 10:36 AM
05/02/09 10:36 AM
Posts: 366 San Gabriel, CA 91775
rexus31
How much did you take off? What is your compression ratio? Chamber volume?
As it stands right now, if I bolt my Stealths on my 383 (.030 over, slug .035 in the hole) I'm at 8.8:1. This is basically a stock spec street motor with a .450 lift cam; very mild. I got the Stealths becasue of their affordability and close resemblance to a stock casting more so than their added performance. I'm just wondering if I should mill them or run them as is.
2007 Dodge Charger R/T, Road and Track Performance Group, Steel Blue
1965 Chrysler 300 Convertible, 383 4V, 727TF, Factory Air, Spanish Red
1964 Pontiac GTO, Tri-Power, 4 Speed, Grenadier Red
"What ain't no country I ever heard of. They speak English in What?" - Jules Winnfield
Re: Who has milled their Stealths?
[Re: komninon]
#305375
05/02/09 01:35 PM
05/02/09 01:35 PM
rexus31
my motor is still at the machine shop. is a 440 with stealth heads. i think they milled the heads .050 use fel -pro 1105 gaskets now it is 78cc and compression 10.6 to 1. i will have all the paperwork next week after the dyno.
Thanks. What gas are you planning to use?
[Re: rexus31]
#305376
05/02/09 09:45 PM
05/02/09 09:45 PM
Posts: 1,142 Central New York
slippery440
Crybaby440
Crybaby440
Central New York
Milled .075 started at 84 cc now 72 cc. We had to take .095 o9ff the intake side.I would take half of the head and then the rest off the intake manifold,
If the MODS did their job I would not be hitting the notify MOD button. LOL
[Re: slippery440]
#305378
05/02/09 10:54 PM
05/02/09 10:54 PM
rexus31
Wow....using a web based milling calculator, it would only take .040 to get them down to 72cc. Based on my calculations, milling them .075 would give you 62cc chambers. What's your compression ratio? 440 or 383?
[Re: rexus31]
#305379
05/02/09 10:57 PM
05/02/09 10:57 PM
1_WILD_RT
Management Trainee
Management Trainee
Today? Who Knows?
Was that calculator based on a typical Mopar chamber? cause the Stealths taper quite a bit more than say a 915..
[Re: 1_WILD_RT]
#305380
05/02/09 11:11 PM
05/02/09 11:11 PM
rexus31
Does that mean more material has to be removed to obtain a certain chamber volume?
[Re: 1_WILD_RT]
#305382
05/03/09 03:16 AM
05/03/09 03:16 AM
Posts: 2,465 Sydney,Australia
tex013
Sydney,Australia
cc'd mine at 86/7.milled down for 78cc Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#305384
05/03/09 08:47 AM
05/03/09 08:47 AM
slippery440
Crybaby440
Crybaby440
Central New York
We cc the head 3 times. Once before and then at .045 and then at .075. Kind of suprised me too.We figure about 11.5 or 12 to 1 compression.Block at zero and flat top pistons at .005 out.
[Re: rexus31]
#305385
05/03/09 09:43 AM
05/03/09 09:43 AM
Posts: 16,928 NC
440Jim
NC
As it stands right now, if I bolt my Stealths on my 383 (.030 over, slug .035 in the hole) I'm at 8.8:1. ... I'm just wondering if I should mill them or run them as is.
I would do something to get the CR up higher, unless you insist on running 87 octane. A piston to get zero deck would have been the best choice, but you have to do with what you got. IMO, a 10.0 CR, aluminum head, mild perf cam should be able to run on 92 octane or less.
[Re: rexus31]
#305386
05/04/09 11:50 AM
05/04/09 11:50 AM
Posts: 5,080 organ
maximum entropy
organ
i got a set of the cnc stealths. the chambers were all over the place- 83 to 85.5. i equalised them at 85.5 and had them milled .040 and they measured 76 cc if i remember.
[Re: maximum entropy]
#305387
05/04/09 12:24 PM
05/04/09 12:24 PM
rexus31
Did you have to shave the intake? How much did it cost you to have the heads milled?
[Re: rexus31]
#305388
05/04/09 01:31 PM
05/04/09 01:31 PM
Posts: 5,080 organ
maximum entropy
organ
the machinist i took it to charged me about 70.00. he said he prefers to shave the intake only, to compensate, not the intake side of the heads. not the way i would do it, but, hey, making your machinist irritated seems like a really bad idea, you know?
#305389
05/04/09 03:39 PM
05/04/09 03:39 PM
rexus31
How much did he take off the intake?
[Re: rexus31]
#305390
05/04/09 04:45 PM
05/04/09 04:45 PM
Posts: 5,080 organ
maximum entropy
organ
he didn't take any off of the intake face of the heads, and i haven't mocked up the intake yet- it'll be a couple of weeks. the block was decked .025, btw. i can pm you with the results, if you like?
#305391
05/04/09 09:57 PM
05/04/09 09:57 PM
rexus31
That would be great, thanks!
