Re: 1971 440-6 dist. wiring
[Re: dragon slayer]
#3050359
06/14/22 03:02 AM
06/14/22 03:02 AM
Posts: 1,899 MYRTLE BEACH SOUTH CAROLINA
ek3
those 2 wires hook to somthing. they are not long enough to connect to anything . there must be another pair of connectors that fit on the 2 leads? there is this "blue wire" {photo} ---that also is connected to the idol solinoid. it gets a black clip to mount the wire to that bracket. anyone have a photo of survivior 71 6 pack with this wiring shown?
[Re: ek3]
#3050375
06/14/22 07:16 AM
06/14/22 07:16 AM
Posts: 1,326 VA
dragon slayer
VA
Does the black wire reach the solenoid male terminal at the top of solenoid. I imagine the engine harness for this option would have the power feed harness on it. The 71 service manual shows a DBL wire to the red bullet power feed coming from a #1 splice. Which is the splice in the J2 wire that feed ballast and VR wires. There might be a jumper to get the black wire to the terminal of the solenoid for idle.
[Re: floyd]
#3050563
06/14/22 06:04 PM
06/14/22 06:04 PM
ek3
There’s an additional wiring harness needed for the solenoid. I believe Frank Badalson sells everything (harness clips, etc) thats what i thought . thanks !!!
[Re: floyd]
#3050572
06/14/22 07:21 PM
06/14/22 07:21 PM
ek3
He sells the two clips circled in green as well. i have the blue wire connected. i need the wire shown and clips and the other wire coming out od dist. goes to somthing. its a male red tip plug.
