1971 440-6 dist. wiring #3050313
06/13/22 09:00 PM
06/13/22 09:00 PM
MYRTLE BEACH SOUTH CAROLINA
E
ek3 Offline OP
ek3  Offline OP
E
on the 71 dual point distributors there are 2 extra wires coming out of the retard box. one end is red and one black. where do they connect? there are no places that i am aware of to connect them?
Re: 1971 440-6 dist. wiring [Re: ek3] #3050323
06/13/22 10:03 PM
06/13/22 10:03 PM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
Dual point distributors only have 1 lead coming out of them. Take the cap off and take another picture, you likely have a electronic conversion replacing the points shruggy wink
Re: 1971 440-6 dist. wiring [Re: TJP] #3050326
06/13/22 10:14 PM
06/13/22 10:14 PM
Colleyville
3hundred Offline
3hundred  Offline
Colleyville
He's got the vacuum retard mechanism. I had one decades ago but forget how the retard works. Got rid of it with one of the first Mopar electronic ignition conversions. I recall GM locked out vacuum advance until 3rd gear, they used a solenoid, easily bypassed, just cannot recall what Mopar did.
'68 Fury Convertible
'69 300 Convertible
'15 Durango 5.7 Hemi
'16 300 S Hemi
Re: 1971 440-6 dist. wiring [Re: TJP] #3050328
06/13/22 10:18 PM
06/13/22 10:18 PM
VA
dragon slayer Offline
VA
This is the vacuum solenoid retard. The service manual talks about it in the electrical section chap 8. The bullet is the feed and female goes to ground. I am not sure how the engine harness is set up as I have not seen or worked on one.
Re: 1971 440-6 dist. wiring [Re: dragon slayer] #3050333
06/13/22 10:35 PM
06/13/22 10:35 PM
VA
VA
Re: 1971 440-6 dist. wiring [Re: dragon slayer] #3050359
06/14/22 03:02 AM
06/14/22 03:02 AM
E
ek3 Offline OP
ek3  Offline OP
E
those 2 wires hook to somthing. they are not long enough to connect to anything . there must be another pair of connectors that fit on the 2 leads? there is this "blue wire" {photo} ---that also is connected to the idol solinoid. it gets a black clip to mount the wire to that bracket. anyone have a photo of survivior 71 6 pack with this wiring shown?
Re: 1971 440-6 dist. wiring [Re: ek3] #3050375
06/14/22 07:16 AM
06/14/22 07:16 AM
VA
VA
Does the black wire reach the solenoid male terminal at the top of solenoid. I imagine the engine harness for this option would have the power feed harness on it. The 71 service manual shows a DBL wire to the red bullet power feed coming from a #1 splice. Which is the splice in the J2 wire that feed ballast and VR wires. There might be a jumper to get the black wire to the terminal of the solenoid for idle.
Re: 1971 440-6 dist. wiring [Re: dragon slayer] #3050388
06/14/22 08:19 AM
06/14/22 08:19 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Red connector goes to a dark green which goes to field lug on alternator, black to idle stop solenoid.
C7026385-9E44-43A1-B4FB-AA8D75A3C141.jpegF5D4BEF4-7491-41CE-AFA6-3F4EF376754A.jpeg720A5189-EE9C-4A1F-9482-B857903FCA2F.jpeg
Re: 1971 440-6 dist. wiring [Re: shakerjoe] #3050402
06/14/22 09:12 AM
06/14/22 09:12 AM
MD
floyd Offline
floyd  Offline
MD
There’s an additional wiring harness needed for the solenoid. I believe Frank Badalson sells everything (harness clips, etc)
Re: 1971 440-6 dist. wiring [Re: floyd] #3050416
06/14/22 09:50 AM
06/14/22 09:50 AM
California
biggE Offline
biggE  Offline
California
I have ran that type of vacuum advance on several cars using NOS units. They pretty much seem to fail. I usually just disconnect the wiring and let the advance work manually.
Re: 1971 440-6 dist. wiring [Re: 3hundred] #3050432
06/14/22 10:44 AM
06/14/22 10:44 AM
Omaha Ne
TJP Online content
TJP  Online Content
Omaha Ne
I stand corrected, spank, thank you 3hundred thumbs
Re: 1971 440-6 dist. wiring [Re: floyd] #3050563
06/14/22 06:04 PM
06/14/22 06:04 PM
E
ek3 Offline OP
ek3  Offline OP
E
thats what i thought . thanks !!!
Re: 1971 440-6 dist. wiring [Re: ek3] #3050565
06/14/22 06:50 PM
06/14/22 06:50 PM
MD
floyd Offline
floyd  Offline
MD
He sells the two clips circled in green as well.
Re: 1971 440-6 dist. wiring [Re: floyd] #3050572
06/14/22 07:21 PM
06/14/22 07:21 PM
E
ek3 Offline OP
ek3  Offline OP
E
i have the blue wire connected. i need the wire shown and clips and the other wire coming out od dist. goes to somthing. its a male red tip plug.
Re: 1971 440-6 dist. wiring [Re: ek3] #3050660
06/15/22 09:16 AM
06/15/22 09:16 AM
Long Island, NY
shakerjoe Offline
shakerjoe  Offline
Long Island, NY
Yes
Re: 1971 440-6 dist. wiring [Re: shakerjoe] #3050791
06/15/22 05:25 PM
06/15/22 05:25 PM
E
ek3 Offline OP
ek3  Offline OP
E
thanks ! ! ! I got the clip and extra wire harness from frank and the red wire goes to the alt !! up
Re: 1971 440-6 dist. wiring [Re: ek3] #3050813
06/15/22 07:37 PM
06/15/22 07:37 PM
MD
floyd Offline
floyd  Offline
MD
Sweet! I’m looking forward to seeing the car at Carlisle.
Re: 1971 440-6 dist. wiring [Re: floyd] #3050825
06/15/22 08:46 PM
06/15/22 08:46 PM
E
ek3 Offline OP
ek3  Offline OP
E
the struggle is real ! it may not be perfect by then but i will make it luck
