Re: Front Shock?
[Re: bobs69]
#3050004
06/12/22 06:44 PM
06/12/22 06:44 PM
Posts: 4,672 Wichita
GY3
Wichita
If it's mid 10's or slower, a 90/10 shock works well.
We have used the 3 way Competition Engineering shocks with success.
Re: Front Shock?
[Re: bobs69]
#3050074
06/13/22 02:59 AM
06/13/22 02:59 AM
Posts: 43,173 Bend,OR USA
Cab_Burge
Koni speed sensing steel drag front shocks if you can find them now I have a new set in a old box with a part number of 80 1423SPA1 on the end I put a set of them on my old pump gas Duster(mid to low tens in the 1/4 mile) and they work WAY better than the Comp. Engr, 3 way adjustable front shocks did, way better
Re: Front Shock?
[Re: Cab_Burge]
#3050153
06/13/22 11:09 AM
06/13/22 11:09 AM
Posts: 11,558 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
If the front suspension is separating too aggressively and/or landing, crushing the suspension and bouncing, you need to use a good shock and control both ends independently. $400/pr are not "good" shocks.
Not everyone can benefit from that. You didn't say how fast or how this car is working now.
