Installing a Gear Vendors #3049050
06/09/22 05:07 AM
06/09/22 05:07 AM
On the open road
Hrtbkr Offline OP
Hrtbkr  Offline OP
On the open road
Hi I'm getting ready to install a Gear Vendors in my '71 GTX automatic.
Does anyone have some experience/advice to share?
While outside on the turnpike They got this new hit tune Where thrills become as cheap as gas And gas as cheap as thrills
Re: Installing a Gear Vendors [Re: Hrtbkr] #3049060
06/09/22 06:52 AM
06/09/22 06:52 AM
Abilene, Texas
fastmark Offline
fastmark  Offline
Abilene, Texas
I’m halfway done on a 69 Charger but the unit is in. I had to drop it more than the .100 they said to drop the crossmember. Otherwise I would have had to clearance the whole tunnel for the unit instead of just the bolts at the rear section. They give you a template where it needs to clear. I ended up using smaller 3/8 bolts instead of the factory ones so it dropped it over 3/8”. 71 had 3/8” bolts to begin with but you may be able to drop the motor mount some. This one is close. I hope it does not hit on bumps.
Re: Installing a Gear Vendors [Re: fastmark] #3049085
06/09/22 09:58 AM
06/09/22 09:58 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm no help with that fitment. But I've had one in my GMC Dually (4.10 gears) since 1996 and it's the best modification on the truck.
Utterly bulletproof, needs only an occasional fluid change.
Fortunately there was a place on the dash for the rocker switches, so it even looks factory-installed.
It did require some fiddling with driveshaft angles.
Re: Installing a Gear Vendors [Re: topside] #3049183
06/09/22 06:11 PM
06/09/22 06:11 PM
Downtown Roebuck Ont
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
If I was doing one, I would start with a short tail shaft 727 or replace the output shaft in mine with a short one and get the "Shorty" GV kit.
Kevin
Re: Installing a Gear Vendors [Re: Twostick] #3049500
06/10/22 09:03 PM
06/10/22 09:03 PM
Southington Ct.
turbobitt Offline
turbobitt  Offline
Southington Ct.
Kevin
I tried this on my 70 challenger and the GV would have clobbered the trans x-member and would have needed more extensive modifications I was not willing to do so I went back to the original style.
Now if I were to do it again, I would look into converting to a A-518/46RH. May have to run a conversion bell for a big block but worth the effort. I think I have seen where the tails haft was ground down to clear with less modifications to the car undercarriage for clean install.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy. 1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno. 1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
Re: Installing a Gear Vendors [Re: turbobitt] #3049633
06/11/22 12:08 PM
06/11/22 12:08 PM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
Kevin
AG.
That’s what I did however I should of spent a bit more time measuring. I ended up going with the 46RE only to find I don’t have enough room under the chassis. I can move the exhaust but the fuel tank is a challange. It’s a 20 gallon saddle tank. Don’t really want to lose the capacity by either moving it to the rear of the chassis or the bed. It’s a 52 Dodge PU. I bought the trans complete with converter. So, now I’m trying to figure out which direction to go, rearrange everything or sell the trans and buy a GV.
Abe Lincoln
Re: Installing a Gear Vendors [Re: turbobitt] #3049636
06/11/22 12:12 PM
06/11/22 12:12 PM
moparx Offline
moparx  Offline
i priced out a 727/gearvendor setup against a 518[46rh] setup, and found that one could come out money and modifications ahead by doing a 518.
this included a torque converter, transmission rebuild, beefed up transmission internal components, and a jw ultrabell.
this was with me doing all the work except making up a driveshaft. [which would be roughly the same price no matter which direction a person went]
just my opinion, using my tools and skills. your mileage will vary.
beer
Re: Installing a Gear Vendors [Re: moparx] #3049679
06/11/22 02:28 PM
06/11/22 02:28 PM
Northern OH
rapom Offline
rapom  Offline
Northern OH
I install a GV shorty unit in a 68 satellite. A lot of crossmember fab was need. But, it gives a better driveshaft angle. Still have to test yet.
I did a regular one in my 67 coronet, and that works great. Got to put it up as high as you can in the tunnel.
Re: Installing a Gear Vendors [Re: rapom] #3049896
06/12/22 11:58 AM
06/12/22 11:58 AM
Twostick Offline
Still wishing...
Twostick  Offline
Still wishing...
Just so I'm on the same page, does the shorty use the motorhome/truck short tail trans or the 4x4 case?
I'm puzzled because I thought the short truck trans had its mount in the same location as the car 727. I would expect the rear crossmember to clear the same because the GV adapter should just be shorter length but still be the same dimensions at the mount.
If it uses the 4x4 case I could see that being problematic.
Kevin
