SOLID LIFTER #3047355
06/02/22 12:11 PM
06/02/22 12:11 PM
westerly, ri. usa
440lebaron Offline OP
westerly, ri. usa
solid lifters name brand "sealed power" made in china, not much to it, everything else is backordered, any input?
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: SOLID LIFTER [Re: 440lebaron] #3047361
06/02/22 12:28 PM
06/02/22 12:28 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Is the application a cheater cam for an NHRA Stocker, using the typical spring force associated with that type of cam?
If so, then I’d go another route.
Re: SOLID LIFTER [Re: fast68plymouth] #3047365
06/02/22 12:41 PM
06/02/22 12:41 PM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
There are howards edm on ebay but spendy. Also comp std. solid and edms.
All in the $275 to $350 area.
STOP POTATO HATE!
Re: SOLID LIFTER [Re: Mr PotatoHead] #3047393
06/02/22 02:06 PM
06/02/22 02:06 PM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I'm an EDM fan myself; last thing I need is a wiped FT cam.
Do it once, do it right.
Re: SOLID LIFTER [Re: Mr PotatoHead] #3047409
06/02/22 03:08 PM
06/02/22 03:08 PM
EDM lifters were made and designed to be used in BB Chevy motors due to their poor lubrication of the lifters and cam lobes and tight lifter to lifter bore clearances: work: scope
Every BB Mopar I've check the lifter bores on have a BUNCH of lifter to lifter bore clearances scope
I've primed more than one BB,SB and Gen 2 426 C.I. hemi motors with the lifter gallery expose, they flat push a lot of oil out around the lifters under pressure scope
My message is we don't need EDM lifters, use a good oil high in Zinc content instead to make the cam and lifters live up twocents
Re: SOLID LIFTER [Re: Cab_Burge] #3047426
06/02/22 03:43 PM
06/02/22 03:43 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
I’m sold on EDM lifters. I ran them for five years on a .650 lift solid cam and everything looks great.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: SOLID LIFTER [Re: 440lebaron] #3047446
06/02/22 05:29 PM
06/02/22 05:29 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Maybe a return to some of the old ways, machining the old parts and reusing materials, is in order.
http://schneidercams.com/Lifter_Resurfacing.aspx
Of course, if you don't happen to have any used lifters on hand to reface, then this won't help a whole lot.
We've all been told repeatedly to throw them away at every rebuild for many years, maybe time for that kind of thing to stop.
Rich H.
Esse Quam Videri
Re: SOLID LIFTER [Re: ZIPPY] #3047534
06/02/22 10:49 PM
06/02/22 10:49 PM
I've had several sets of OEM Mopar solid hemi lifters, both sizes, and OEM Mopar brand low tapered hydraulic lifters refaced in Seatle and reused them, works good, last a long time boogie up
Re: SOLID LIFTER [Re: Cab_Burge] #3047719
06/03/22 06:33 PM
06/03/22 06:33 PM
Central TEXAS!!!!
sr4440 Offline
sr4440  Offline
Central TEXAS!!!!
I know several builders that use these guys, rebuilding lifters is all they do.
https://mizpahprecision.com/index.htm
Joe
Without Data, you’re just another guy with an opinion.
Re: SOLID LIFTER [Re: Cab_Burge] #3047723
06/03/22 07:34 PM
06/03/22 07:34 PM
A727Tflite Offline
A727Tflite  Offline
Have a name of the company that did it for you ?
Re: SOLID LIFTER [Re: Cab_Burge] #3047875
06/04/22 02:02 PM
06/04/22 02:02 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
[/quote]
My message is we don't need EDM lifters, use a good oil high in Zinc content instead to make the cam and lifters live up twocents [/quote]
The Chrysler service manuals show a lifter bore size of 0.9050" to 0.9058". I believe the aftermarket has sized their lifters for a slightly smaller size, resulting in the lifter bore flooding. I talked to Billy Godbold at CC about it. He said he changed the lifter size when he first got to Comp, but they had complaints from the Brand X racers and they changed it back.
Floyd Lippencott IV
Re: SOLID LIFTER [Re: 440lebaron] #3047989
06/05/22 09:47 AM
06/05/22 09:47 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
jonescams@bellsouth.net has American made flat tappet cam and lifters, he also designs some very good camshaft profiles, he picked my car up a couple tenths. I have run the EDM solid lifters with good results and on hydraulic cams I have grooved the lifter bores for better oiling seems to work very well. But in changing with the times I just have been building most mild engines with a hydraulic roller.
Re: SOLID LIFTER [Re: jwb123] #3048022
06/05/22 12:56 PM
06/05/22 12:56 PM
Super Spudsville
Half Baked
Half Baked
Super Spudsville
But really if your pumping enough oil to all the needed places is there a downside to edm lifters.
Ive some older vintage cams I feel will be fine with std solids, I rum many comp solid cams that some dont like due to the steep ramps and in that application isnt more lube dead center of the lifter a benefit in higher stress situations.?
STOP POTATO HATE!
