SOLID LIFTER
#3047355
06/02/22 12:11 PM
06/02/22 12:11 PM
Posts: 1,602 westerly, ri. usa
440lebaron
westerly, ri. usa
solid lifters name brand "sealed power" made in china, not much to it, everything else is backordered, any input?
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
Re: SOLID LIFTER
[Re: 440lebaron]
#3047361
06/02/22 12:28 PM
06/02/22 12:28 PM
Posts: 14,492 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Is the application a cheater cam for an NHRA Stocker, using the typical spring force associated with that type of cam?
If so, then I’d go another route.
Re: SOLID LIFTER
[Re: Mr PotatoHead]
#3047409
06/02/22 03:08 PM
06/02/22 03:08 PM
Posts: 43,099 Bend,OR USA
Cab_Burge
There are howards edm on ebay but spendy. Also comp std. solid and edms.
All in the $275 to $350 area. EDM lifters were made and designed to be used in BB Chevy motors due to their poor lubrication of the lifters and cam lobes and tight lifter to lifter bore clearances: work: Every BB Mopar I've check the lifter bores on have a BUNCH of lifter to lifter bore clearances I've primed more than one BB,SB and Gen 2 426 C.I. hemi motors with the lifter gallery expose, they flat push a lot of oil out around the lifters under pressure My message is we don't need EDM lifters, use a good oil high in Zinc content instead to make the cam and lifters live
Re: SOLID LIFTER
[Re: Cab_Burge]
#3047426
06/02/22 03:43 PM
06/02/22 03:43 PM
Posts: 20,151 PA.
pittsburghracer
"Little"John
"Little"John
PA.
I’m sold on EDM lifters. I ran them for five years on a .650 lift solid cam and everything looks great.
Re: SOLID LIFTER
[Re: 440lebaron]
#3047446
06/02/22 05:29 PM
06/02/22 05:29 PM
Posts: 17,838 S.E. Michigan
ZIPPY
S.E. Michigan
Maybe a return to some of the old ways, machining the old parts and reusing materials, is in order. http://schneidercams.com/Lifter_Resurfacing.aspxOf course, if you don't happen to have any used lifters on hand to reface, then this won't help a whole lot. We've all been told repeatedly to throw them away at every rebuild for many years, maybe time for that kind of thing to stop.
Rich H.
Esse Quam Videri
Re: SOLID LIFTER
[Re: Cab_Burge]
#3047875
06/04/22 02:02 PM
06/04/22 02:02 PM
Posts: 3,504 DFW
mr_340
DFW
[/quote] EDM lifters were made and designed to be used in BB Chevy motors due to their poor lubrication of the lifters and cam lobes and tight lifter to lifter bore clearances: work: Every BB Mopar I've check the lifter bores on have a BUNCH of lifter to lifter bore clearances I've primed more than one BB,SB and Gen 2 426 C.I. hemi motors with the lifter gallery expose, they flat push a lot of oil out around the lifters under pressure My message is we don't need EDM lifters, use a good oil high in Zinc content instead to make the cam and lifters live [/quote] The Chrysler service manuals show a lifter bore size of 0.9050" to 0.9058". I believe the aftermarket has sized their lifters for a slightly smaller size, resulting in the lifter bore flooding. I talked to Billy Godbold at CC about it. He said he changed the lifter size when he first got to Comp, but they had complaints from the Brand X racers and they changed it back.
Floyd Lippencott IV
Re: SOLID LIFTER
[Re: jwb123]
#3048022
06/05/22 12:56 PM
06/05/22 12:56 PM
Posts: 9,397 Super Spudsville
Mr PotatoHead
Half Baked
Half Baked
Super Spudsville
But really if your pumping enough oil to all the needed places is there a downside to edm lifters.
Ive some older vintage cams I feel will be fine with std solids, I rum many comp solid cams that some dont like due to the steep ramps and in that application isnt more lube dead center of the lifter a benefit in higher stress situations.?
STOP POTATO HATE!
