Re: who does cnc head porting ?
[Re: fbs63]
#3041399
05/11/22 07:03 AM
05/11/22 07:03 AM
Posts: 11,561 Portage,michigan
B3422W5
Portage,michigan
All the cnc head porters are backed up. That being said contact Scott Brown at buyracingparts.com. He has some great programs for Mopar heads. I think he uses Modern to do his stuff, or at least he used to.
69 Dart GTS A4 Silver All steel, flat factory hood, 3350 race weight 418 BPE factory replacement headed stroker Best so far, 10.68 at 124.48 1.44 best 60 foot. 6.76 at 101.63 best 1 /8
[Re: 572B1]
#3041423
05/11/22 08:51 AM
05/11/22 08:51 AM
Posts: 4,159 Wichita
GY3
Wichita
440 source has them in stock. Interesting. I wonder if they got their issues worked out with Modern?
[Re: GY3]
#3041436
05/11/22 09:52 AM
05/11/22 09:52 AM
Posts: 17,403 S.E. Michigan
ZIPPY
S.E. Michigan
440 source has them in stock. Interesting. I wonder if they got their issues worked out with Modern? Last I heard, they were asking around for someone to go try to get their pallet of heads back. I'd probably try KG if I were in the market. https://www.facebook.com/profile.php?id=100057228979563
Rich H.
[Re: ZIPPY]
#3041454
05/11/22 11:05 AM
05/11/22 11:05 AM
Posts: 14,171 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
My impression is that 440 Source has someone other than Modern doing the cnc work now. I suspect a phone call would clarify that. Also, in the recent overview on a cnc Stealth head by Eric Weingartner where you could see the chamber side of the head, the chamber wasn’t ported like when Modern did them, and it looked to me like the same valve job that comes on the unported heads. https://m.youtube.com/watch?v=ti4RZOQrMvk
[Re: fbs63]
#3041486
05/11/22 12:09 PM
05/11/22 12:09 PM
Posts: 4,468 On the parachute mount
n20mstr
All the cnc head porters are backed up. That being said contact Scott Brown at buyracingparts.com. He has some great programs for Mopar heads. X2 On Scott Brown, He will do a great job , but you have to remember the current state of supply is horrible. You may have to wait no matter who you use....as businesses are short not only on the supplies and materials they use, but it is getting harder to get quality workers...
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3041493
05/11/22 12:18 PM
05/11/22 12:18 PM
B3422W5
Portage,michigan
All the cnc head porters are backed up. That being said contact Scott Brown at buyracingparts.com. He has some great programs for Mopar heads. X2 On Scott Brown, He will do a great job , but you have to remember the current state of supply is horrible. You may have to wait no matter who you use....as businesses are short not only on the supplies and materials they use, but it is getting harder to get quality workers... Like I said above, Scott doesn’t do porting, he sends it out. He used to use Modern to do the porting work he sold. Not sure currently who he uses, might still be Modern.
[Re: fast68plymouth]
#3041499
05/11/22 12:32 PM
05/11/22 12:32 PM
Posts: 810 Loudoun County, VA
Brad_Haak
Loudoun County, VA
My impression is that 440 Source has someone other than Modern doing the cnc work now. I suspect a phone call would clarify that. Also, in the recent overview on a cnc Stealth head by Eric Weingartner where you could see the chamber side of the head, the chamber wasn’t ported like when Modern did them, and it looked to me like the same valve job that comes on the unported heads. https://m.youtube.com/watch?v=ti4RZOQrMvk That's definitely not the same level of CNC and seat & valve work that the Stealths used to get from Modern.  I didn't watch the entire vid to get the rest of EW's review.
2021 Challenger 6.4L Scat Pack 1320 (2022) 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008) pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
#3041505
05/11/22 12:46 PM
05/11/22 12:46 PM
GY3
Wichita
My impression is that 440 Source has someone other than Modern doing the cnc work now. I suspect a phone call would clarify that. Also, in the recent overview on a cnc Stealth head by Eric Weingartner where you could see the chamber side of the head, the chamber wasn’t ported like when Modern did them, and it looked to me like the same valve job that comes on the unported heads. https://m.youtube.com/watch?v=ti4RZOQrMvk I really like Eric's Youtube channel. Very interesting stuff.
[Re: GY3]
#3041506
05/11/22 12:54 PM
05/11/22 12:54 PM
Brad_Haak
Loudoun County, VA
I really like Eric's Youtube channel. Very interesting stuff. It would be nice if he figured out how to pronounce the brand of his own flow bench correctly. It's spelled S-a-e-n-z... pronounced "Sigh-enz" (it's a Spanish surname)... and he keeps calling it "San-yez."
[Re: Brad_Haak]
#3041510
05/11/22 01:00 PM
05/11/22 01:00 PM
GY3
Wichita
I really like Eric's Youtube channel. Very interesting stuff. It would be nice if he figured out how to pronounce the brand of his own flow bench correctly. It's spelled S-a-e-n-z... pronounced "Sigh-enz" (it's a Spanish surname)... and he keeps calling it "San-yez." He's an Okie so he gets a pass.
[Re: GY3]
#3041530
05/11/22 02:03 PM
05/11/22 02:03 PM
fast68plymouth
So. Burlington, Vt.
If one of the new version cnc’d Stealths finds its way to my shop I’ll take some measurements to compare to the MCH cnc’d Stealth I checked out a few years ago.
My “expectation” is that I’d see a higher flow number on my bench than Eric saw on his. I think it was 286@.800” on his bench, which seems pretty soft for a fully ported head.
[Re: GY3]
#3041559
05/11/22 03:21 PM
05/11/22 03:21 PM
Brad_Haak
Loudoun County, VA
I really like Eric's Youtube channel. Very interesting stuff. It would be nice if he figured out how to pronounce the brand of his own flow bench correctly. It's spelled S-a-e-n-z... pronounced "Sigh-enz" (it's a Spanish surname)... and he keeps calling it "San-yez." He's an Okie so he gets a pass. Chad Speier mispronounces it the same as Eric W. Chad is from Kansas... what's his excuse?
[Re: Brad_Haak]
#3041571
05/11/22 04:04 PM
05/11/22 04:04 PM
GY3
Wichita
I really like Eric's Youtube channel. Very interesting stuff. It would be nice if he figured out how to pronounce the brand of his own flow bench correctly. It's spelled S-a-e-n-z... pronounced "Sigh-enz" (it's a Spanish surname)... and he keeps calling it "San-yez." He's an Okie so he gets a pass. Chad Speier mispronounces it the same as Eric W. Chad is from Kansas... what's his excuse? Maybe they're related?
[Re: procharged 484]
#3041597
05/11/22 05:52 PM
05/11/22 05:52 PM
Posts: 2,679 Pattison Texas
csk
Pattison Texas
I have access to a new haas 4 axis machine . Will that cnc heads or does it have to be 5 axis Not sure about 4 or 5 axis needed, but the other issue is a good program for the 440 source heads
1968 Charger COLD A/C Hilborn EFI 512ci 9.7 compression, Stealth heads, 4.10 gear A518 ODtrans 4100lb,10.93 full street car trim 2020 T/A 392
[Re: csk]
#3041601
05/11/22 06:02 PM
05/11/22 06:02 PM
Posts: 19,653 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Some people think you just bolt a head down and flip the power on. Instant cnc’d head. Good luck with that.
#3041605
05/11/22 06:24 PM
05/11/22 06:24 PM
Posts: 6,030 Melbourne , Australia
LA360
I have access to a new haas 4 axis machine . Will that cnc heads or does it have to be 5 axis It's not going to be able to access the entire port without the 5th axis.
Alan Jones
