Page 1 of 3 1 2 3
who does cnc head porting ? #3041377
05/11/22 06:08 AM
05/11/22 06:08 AM
qc
mxbeep Offline OP
mxbeep  Offline OP
qc
I need a set of Stealth heads ported, Hughes no longer does CNC porting, i wished Dwayne Porter could do them but he as well no longer offers the service, however he was kind enough to recommend me to KG engines, which i have been trying to get a hold for the last few months without any answer or replys from them.
Anyone know of a machine shop who offers CNC porting aside from the 3 mentioned?
thanks in advance
Re: who does cnc head porting ? [Re: mxbeep] #3041386
05/11/22 07:11 AM
05/11/22 07:11 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
All the cnc head porters are backed up. That being said contact Scott Brown at buyracingparts.com. He has some great programs for Mopar heads.
Re: who does cnc head porting ? [Re: fbs63] #3041392
05/11/22 07:37 AM
05/11/22 07:37 AM
Brisbane Australia
572B1 Offline
572B1  Offline
Brisbane Australia
440 source has them in stock.
Re: who does cnc head porting ? [Re: fbs63] #3041399
05/11/22 08:03 AM
05/11/22 08:03 AM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
I think he uses Modern to do his stuff, or at least he used to.
Best so far, 10.40 @127 1/4
1.41 best 60 foot
6.60 at 103.90 1/8
Re: who does cnc head porting ? [Re: 572B1] #3041423
05/11/22 09:51 AM
05/11/22 09:51 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
Interesting.
I wonder if they got their issues worked out with Modern?
'63 Dodge 330
11.19 @ 121 mph
Re: who does cnc head porting ? [Re: GY3] #3041436
05/11/22 10:52 AM
05/11/22 10:52 AM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
Interesting.
Last I heard, they were asking around for someone to go try to get their pallet of heads back.
I'd probably try KG if I were in the market.
https://www.facebook.com/profile.php?id=100057228979563
Rich H.
Esse Quam Videri
Re: who does cnc head porting ? [Re: ZIPPY] #3041454
05/11/22 12:05 PM
05/11/22 12:05 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
My impression is that 440 Source has someone other than Modern doing the cnc work now.
I suspect a phone call would clarify that.
Also, in the recent overview on a cnc Stealth head by Eric Weingartner where you could see the chamber side of the head, the chamber wasn’t ported like when Modern did them, and it looked to me like the same valve job that comes on the unported heads.
https://m.youtube.com/watch?v=ti4RZOQrMvk
Re: who does cnc head porting ? [Re: fbs63] #3041486
05/11/22 01:09 PM
05/11/22 01:09 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
X2 On Scott Brown, He will do a great job , but you have to remember the current state of supply is horrible. You may have to wait no matter who you use....as businesses are short not only on the supplies and materials they use, but it is getting harder to get quality workers...
....BAD A$$ STREET CAR.....
Re: who does cnc head porting ? [Re: n20mstr] #3041493
05/11/22 01:18 PM
05/11/22 01:18 PM
Portage,michigan
B3422W5 Offline
B3422W5  Offline
Portage,michigan
Like I said above, Scott doesn’t do porting, he sends it out. He used to use Modern to do the porting work he sold. Not sure currently who he uses, might still be Modern.
1.41 best 60 foot
6.60 at 103.90 1/8
Re: who does cnc head porting ? [Re: fast68plymouth] #3041499
05/11/22 01:32 PM
05/11/22 01:32 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
That's definitely not the same level of CNC and seat & valve work that the Stealths used to get from Modern. scope I didn't watch the entire vid to get the rest of EW's review.
2021 Challenger 6.4L Scat Pack 1320 (2022)
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
wheels, tires, air filter: 1.714, 11.833 at 115.80 (DA 310 ft)
1973 Challenger 452 ci street/strip (2008)
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
Re: who does cnc head porting ? [Re: fast68plymouth] #3041505
05/11/22 01:46 PM
05/11/22 01:46 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I really like Eric's Youtube channel. Very interesting stuff.
'63 Dodge 330
11.19 @ 121 mph
Re: who does cnc head porting ? [Re: GY3] #3041506
05/11/22 01:54 PM
05/11/22 01:54 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
It would be nice if he figured out how to pronounce the brand of his own flow bench correctly. It's spelled S-a-e-n-z... pronounced "Sigh-enz" (it's a Spanish surname)... and he keeps calling it "San-yez." no
Re: who does cnc head porting ? [Re: Brad_Haak] #3041510
05/11/22 02:00 PM
05/11/22 02:00 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
He's an Okie so he gets a pass. grin
'63 Dodge 330
11.19 @ 121 mph
Re: who does cnc head porting ? [Re: GY3] #3041530
05/11/22 03:03 PM
05/11/22 03:03 PM
So. Burlington, Vt.
So. Burlington, Vt.
If one of the new version cnc’d Stealths finds its way to my shop I’ll take some measurements to compare to the MCH cnc’d Stealth I checked out a few years ago.
My “expectation” is that I’d see a higher flow number on my bench than Eric saw on his.
I think it was 286@.800” on his bench, which seems pretty soft for a fully ported head.
Re: who does cnc head porting ? [Re: GY3] #3041559
05/11/22 04:21 PM
05/11/22 04:21 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
Chad Speier mispronounces it the same as Eric W. Chad is from Kansas... what's his excuse? laugh2
Re: who does cnc head porting ? [Re: Brad_Haak] #3041571
05/11/22 05:04 PM
05/11/22 05:04 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
Maybe they're related? shruggy
'63 Dodge 330
11.19 @ 121 mph
Re: who does cnc head porting ? [Re: GY3] #3041587
05/11/22 05:53 PM
05/11/22 05:53 PM
napa ca
P
procharged 484 Offline
P
napa ca
I have access to a new haas 4 axis machine . Will that cnc heads or does it have to be 5 axis
Re: who does cnc head porting ? [Re: procharged 484] #3041597
05/11/22 06:52 PM
05/11/22 06:52 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Not sure about 4 or 5 axis needed, but the other issue is a good program for the 440 source heads
Re: who does cnc head porting ? [Re: CSK] #3041601
05/11/22 07:02 PM
05/11/22 07:02 PM
PA.
pittsburghracer Online work
"Little"John
pittsburghracer  Online Work
"Little"John
PA.
Some people think you just bolt a head down and flip the power on. Instant cnc’d head. Good luck with that.
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: who does cnc head porting ? [Re: procharged 484] #3041605
05/11/22 07:24 PM
05/11/22 07:24 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
It's not going to be able to access the entire port without the 5th axis.
Alan Jones
Page 1 of 3 1 2 3
