Smoke with head flow testing #3039852
05/05/22 12:26 AM
05/05/22 12:26 AM
Minnesota
Hemi_Joel Offline OP
Minnesota
Does anyone use smoke with cylinder head flow testing to observe the flow patterns? If so what do you use to generate the smoke? Thanks, Joel
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Smoke with head flow testing [Re: Hemi_Joel] #3039854
05/05/22 12:35 AM
05/05/22 12:35 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
A mechanic next door has a smoke machine for detecting leaks in the vacuum hoses, puts out a lot of smoke under pressure. I’m sure this machine would work ok for testing
Re: Smoke with head flow testing [Re: cudaman1969] #3039876
05/05/22 07:42 AM
05/05/22 07:42 AM
usa
lewtot184 Offline
lewtot184  Offline
usa
there used to be a simple smoke stick that could be introduced in the air flow. we used to use them at work. i've always thought a smoke test would make sense because it will give a visual on air flow but not sure if anybody does it.
Re: Smoke with head flow testing [Re: lewtot184] #3039890
05/05/22 09:14 AM
05/05/22 09:14 AM
Tulsa OK
Bad340fish Online content
Bad340fish  Online Content
Tulsa OK
But the smoke may not act the same as the atomized fuel, so its hard to tell if that is really what is going to go on.
68 Barracuda Formula S 340
Re: Smoke with head flow testing [Re: Bad340fish] #3039901
05/05/22 10:02 AM
05/05/22 10:02 AM
Brisvegas, Australia
Alchemi Offline
Alchemi  Offline
How about a fog machine? vaporized water is much closer to fuel than smoke
They are much cheaper than they used to be
Re: Smoke with head flow testing [Re: Alchemi] #3039905
05/05/22 10:17 AM
05/05/22 10:17 AM
Minnesota
Minnesota
That's a great idea. I actually have a fog machine that I bought for fogging the inside of a building with moldicide when I was doing a mold abatement. I'm going to try it!
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Smoke with head flow testing [Re: Hemi_Joel] #3040026
05/05/22 05:53 PM
05/05/22 05:53 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I imagine it's very messy, but I have read in various discussions of guys like Darin Morgan, Chad Spier and Curtis Boggs spraying dykem in the air near the head whilst they have the flow bench running. The dykem sticks to the port and chamber as the air goes through it.
Alan Jones
Re: Smoke with head flow testing [Re: LA360] #3040030
05/05/22 06:13 PM
05/05/22 06:13 PM
Minnesota
Minnesota
That does sound messy! But I could see where it would help identify dead areas.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: Smoke with head flow testing [Re: LA360] #3040062
05/05/22 07:20 PM
05/05/22 07:20 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I wonder if something could be added to the water in the fog machine to show similar results? Maybe food coloring?
Re: Smoke with head flow testing [Re: Hemi_Joel] #3040223
05/06/22 08:51 AM
05/06/22 08:51 AM
northern,Ohio,USA
Clanton Offline
Clanton  Offline
northern,Ohio,USA
Search Darrin Morgan on youtube and he has a video using Dykem in the flowbench and shows results and how to read them
Re: Smoke with head flow testing [Re: Hemi_Joel] #3040237
05/06/22 09:23 AM
05/06/22 09:23 AM
Tulsa OK
Tulsa OK
Maybe my Dad will chime in here with who did the work. My W2 heads were "wet flowed" by someone many years ago. If I remember right he was unhappy with the results and didn't charge my dad for the port work that had been done. Fast forward to 2015 we sent those heads and block etc to shady dell to be machined and all Ryan did was touch the heads up a little and they flow like 318@.700 or something near that. The motor is 7 years old now and makes around 600HP with 10:1 compression on 91 octane so they could never have been all that bad? So as wet flow this guy deemed them junk, Ryan deemed them just fine through standard methods, and they perform well. Sounds like drag racing to me shruggy grin
Re: Smoke with head flow testing [Re: Bad340fish] #3040543
05/07/22 12:11 PM
05/07/22 12:11 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
That was Vance Cummins. He raced a Dart in IHRA's Top Stock at the time in Rod Shop livery. Vance has/had a Wet Flow bench. He was unhappy that he could not keep the heads from getting turbulent at higher RPMs. Like Clark said Ryan either was not concerned or fixed them.
Re: Smoke with head flow testing [Re: Hemi_Joel] #3040604
05/07/22 04:04 PM
05/07/22 04:04 PM
Loudoun County, VA
Brad_Haak Offline
Brad_Haak  Offline
Loudoun County, VA
If not mentioned already, Mike Chapman used smoke testing before wet-flow testing became more accessible.
2021 Challenger 6.4L Scat Pack 1320
100% stock: 1.680, 11.894 at 113.75 (DA 175 ft)
weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008]
pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
