Smoke with head flow testing
#3039852
05/05/22 12:26 AM
05/05/22 12:26 AM
Posts: 7,489 Minnesota
Hemi_Joel
Minnesota
Does anyone use smoke with cylinder head flow testing to observe the flow patterns? If so what do you use to generate the smoke? Thanks, Joel
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
Re: Smoke with head flow testing
[Re: lewtot184]
#3039890
05/05/22 09:14 AM
05/05/22 09:14 AM
Posts: 8,022 Tulsa OK
Bad340fish
Tulsa OK
there used to be a simple smoke stick that could be introduced in the air flow. we used to use them at work. i've always thought a smoke test would make sense because it will give a visual on air flow but not sure if anybody does it. But the smoke may not act the same as the atomized fuel, so its hard to tell if that is really what is going to go on.
68 Barracuda Formula S 340
[Re: Alchemi]
#3039905
05/05/22 10:17 AM
05/05/22 10:17 AM
Hemi_Joel
Minnesota
How about a fog machine? vaporized water is much closer to fuel than smoke They are much cheaper than they used to be That's a great idea. I actually have a fog machine that I bought for fogging the inside of a building with moldicide when I was doing a mold abatement. I'm going to try it!
[Re: Hemi_Joel]
#3040026
05/05/22 05:53 PM
05/05/22 05:53 PM
Posts: 6,139 Melbourne , Australia
LA360
I imagine it's very messy, but I have read in various discussions of guys like Darin Morgan, Chad Spier and Curtis Boggs spraying dykem in the air near the head whilst they have the flow bench running. The dykem sticks to the port and chamber as the air goes through it.
Alan Jones
[Re: LA360]
#3040030
05/05/22 06:13 PM
05/05/22 06:13 PM
Hemi_Joel
Minnesota
I imagine it's very messy, but I have read in various discussions of guys like Darin Morgan, Chad Spier and Curtis Boggs spraying dykem in the air near the head whilst they have the flow bench running. The dykem sticks to the port and chamber as the air goes through it. That does sound messy! But I could see where it would help identify dead areas.
[Re: LA360]
#3040062
05/05/22 07:20 PM
05/05/22 07:20 PM
Posts: 1,061 Atlanta, GA
mgoblue9798
Atlanta, GA
I imagine it's very messy, but I have read in various discussions of guys like Darin Morgan, Chad Spier and Curtis Boggs spraying dykem in the air near the head whilst they have the flow bench running. The dykem sticks to the port and chamber as the air goes through it. I wonder if something could be added to the water in the fog machine to show similar results? Maybe food coloring?
[Re: Hemi_Joel]
#3040237
05/06/22 09:23 AM
05/06/22 09:23 AM
Bad340fish
Tulsa OK
I imagine it's very messy, but I have read in various discussions of guys like Darin Morgan, Chad Spier and Curtis Boggs spraying dykem in the air near the head whilst they have the flow bench running. The dykem sticks to the port and chamber as the air goes through it. That does sound messy! But I could see where it would help identify dead areas. Maybe my Dad will chime in here with who did the work. My W2 heads were "wet flowed" by someone many years ago. If I remember right he was unhappy with the results and didn't charge my dad for the port work that had been done. Fast forward to 2015 we sent those heads and block etc to shady dell to be machined and all Ryan did was touch the heads up a little and they flow like 318@.700 or something near that. The motor is 7 years old now and makes around 600HP with 10:1 compression on 91 octane so they could never have been all that bad? So as wet flow this guy deemed them junk, Ryan deemed them just fine through standard methods, and they perform well. Sounds like drag racing to me
[Re: Bad340fish]
#3040543
05/07/22 12:11 PM
05/07/22 12:11 PM
Posts: 3,510 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
I imagine it's very messy, but I have read in various discussions of guys like Darin Morgan, Chad Spier and Curtis Boggs spraying dykem in the air near the head whilst they have the flow bench running. The dykem sticks to the port and chamber as the air goes through it. That does sound messy! But I could see where it would help identify dead areas. Maybe my Dad will chime in here with who did the work. My W2 heads were "wet flowed" by someone many years ago. If I remember right he was unhappy with the results and didn't charge my dad for the port work that had been done. Fast forward to 2015 we sent those heads and block etc to shady dell to be machined and all Ryan did was touch the heads up a little and they flow like 318@.700 or something near that. The motor is 7 years old now and makes around 600HP with 10:1 compression on 91 octane so they could never have been all that bad? So as wet flow this guy deemed them junk, Ryan deemed them just fine through standard methods, and they perform well. Sounds like drag racing to me That was Vance Cummins. He raced a Dart in IHRA's Top Stock at the time in Rod Shop livery. Vance has/had a Wet Flow bench. He was unhappy that he could not keep the heads from getting turbulent at higher RPMs. Like Clark said Ryan either was not concerned or fixed them.
[Re: Hemi_Joel]
#3040604
05/07/22 04:04 PM
05/07/22 04:04 PM
Posts: 1,126 Loudoun County, VA
Brad_Haak
Loudoun County, VA
If not mentioned already, Mike Chapman used smoke testing before wet-flow testing became more accessible.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
