greasing front wheel bearings #3039823
05/04/22 10:01 PM
05/04/22 10:01 PM
ohio
dragon Offline OP
dragon  Offline OP
ohio
Why would you put grease on anything except the bearing and races I took the Anglia hub off and the center was packed with grease it looked like they put a can of grease in there I seen this before do not under stand. Thanks
Re: greasing front wheel bearings [Re: dragon] #3039832
05/04/22 10:49 PM
05/04/22 10:49 PM
Kirkland, Washington
Pacnorthcuda Offline
It’s to prevent any formation of rust which could then find its way to the bearings.
Re: greasing front wheel bearings [Re: dragon] #3039847
05/05/22 12:14 AM
05/05/22 12:14 AM
Boise
Moparteacher Offline
Boise
It's also a way to store grease for the next packing. It's an old trick mostly seen on older European cars. This is my understanding.
Re: greasing front wheel bearings [Re: Moparteacher] #3039848
05/05/22 12:21 AM
05/05/22 12:21 AM
Minnesota
Hemi_Joel Offline
Hemi_Joel  Offline
Minnesota
To help the grease from coming out of the races. The idea is that grease can migrate to an empty space, but not to where there is already more grease.
RS23J71
RS27J77
RP23J71
RO23J71
WM21J8A
Re: greasing front wheel bearings [Re: dragon] #3039893
05/05/22 09:20 AM
05/05/22 09:20 AM
Missouri
jwb123 Offline
jwb123  Offline
Missouri
You can over do it, but as mentioned, keeping the grease in the bearings is the goal, and preventing rust on the spindle, remember that as heat builds in the bearing the grease does not stay thick, it melts and becomes more liquid. Take a heat gun and see what it does to the grease you are using.
Re: greasing front wheel bearings [Re: jwb123] #3039942
05/05/22 11:33 AM
05/05/22 11:33 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Heck I know some Super Stock guys that do not even use any grease....just dip them in STP. Way less drag on the wheel. Same guy had the bearings adjusted out so far that the cotter pin would not even go in. Less drag...works to but kiddies DO NOT try that at home. Todd
Re: greasing front wheel bearings [Re: sasquatch] #3039957
05/05/22 01:15 PM
05/05/22 01:15 PM
West Coast, USA
jbc426 Offline
jbc426  Offline
West Coast, USA
Old autoshop teacher explained why almost 50 years ago. The reasons mentioned above are why. Don't fill the cavity between the inner and out bearings completely and don't forget to put a coating on the inside of the dust cap to prevent rust there too.
Re: greasing front wheel bearings [Re: dragon] #3040064
05/05/22 07:24 PM
05/05/22 07:24 PM
Atlanta, GA
mgoblue9798 Offline
mgoblue9798  Offline
Atlanta, GA
I fill mine on my boat trailer axle to help prevent water intrusion. Maybe something similar is done for trucks?
Re: greasing front wheel bearings [Re: mgoblue9798] #3040180
05/06/22 04:18 AM
05/06/22 04:18 AM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
I thought a bunch of extra grease holds heat in there. I never had bearing trouble and I don’t pack the cap or anything like that.
I want my fair share
Re: greasing front wheel bearings [Re: SomeCarGuy] #3040234
05/06/22 09:10 AM
05/06/22 09:10 AM
Washington
madscientist Offline
Washington
It takes heat to get the grease to become liquid. Then it cools the hot spot and becomes solid again. There should be grease on the inside of the bearing. Centrifugal force causes it to move out.
Re: greasing front wheel bearings [Re: SomeCarGuy] #3040236
05/06/22 09:10 AM
05/06/22 09:10 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
Doesn't anyone read the FSM?
