Re: greasing front wheel bearings
[Re: Moparteacher]
#3039848
05/05/22 12:21 AM
05/05/22 12:21 AM
Posts: 7,477 Minnesota
Hemi_Joel
Minnesota
To help the grease from coming out of the races. The idea is that grease can migrate to an empty space, but not to where there is already more grease.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: sasquatch]
#3039957
05/05/22 01:15 PM
05/05/22 01:15 PM
Posts: 3,277 West Coast, USA
jbc426
West Coast, USA
Old autoshop teacher explained why almost 50 years ago. The reasons mentioned above are why. Don't fill the cavity between the inner and out bearings completely and don't forget to put a coating on the inside of the dust cap to prevent rust there too.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: mgoblue9798]
#3040180
05/06/22 04:18 AM
05/06/22 04:18 AM
Posts: 10,198 Someplace you aren't
SomeCarGuy
I thought a bunch of extra grease holds heat in there. I never had bearing trouble and I don’t pack the cap or anything like that.
I want my fair share
[Re: SomeCarGuy]
#3040234
05/06/22 09:10 AM
05/06/22 09:10 AM
Posts: 4,457 Washington
madscientist
Washington
I thought a bunch of extra grease holds heat in there. I never had bearing trouble and I don’t pack the cap or anything like that. It takes heat to get the grease to become liquid. Then it cools the hot spot and becomes solid again. There should be grease on the inside of the bearing. Centrifugal force causes it to move out.
[Re: SomeCarGuy]
#3040236
05/06/22 09:10 AM
05/06/22 09:10 AM
Posts: 10,698 North Dakota
6PakBee
North Dakota
Doesn't anyone read the FSM?
