Re: T400 into E Body
[Re: John Burdine]
#3037167
04/26/22 08:16 AM
04/26/22 08:16 AM
Posts: 13,362 Marion, South Carolina [><]
an8sec70cuda
I have no info for you, other than you're probably not gonna get an answer on this here. I'm curious myself, although if I was to change I'd go w/ a powerglide just because of the size difference.
[Re: an8sec70cuda]
#3037170
04/26/22 08:33 AM
04/26/22 08:33 AM
Posts: 4,675 On the parachute mount
n20mstr
A Turbo 400 fits into an A body tunnel...But most likely the t bar crossmember needs to be trimmed or even removed at the top of the tunnel. The Turbo 400 is larger at the tail than the 727 is. In my a body i sliced the crossmember and boxed it back in to make it shorter. Now , i just took it out completely. Other than that i have the stock trans tunnel.
....BAD A$$ STREET CAR.....
[Re: T-bar]
#3037187
04/26/22 09:59 AM
04/26/22 09:59 AM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I did a th400 in my 69 b body with only mode on the x member and posted pics 2 yrs ago. and had lots of room(1" min all over clearence) here is my link th400 topic
[Re: Cab_Burge]
#3037663
04/27/22 04:34 PM
04/27/22 04:34 PM
Posts: 2,916 A shed in England
Tig
A shed in England
Why do you want to run one of those power robbing turbo 400 trannies in a Mopar? Hmmm......I only know of 2 mopars that have done that swap. Both cars were big tyre chassis cars and they both improved ET with no other changes. But....was it down to a better converter.... or the more efficient 2-3 gear change All I know is a TH400 and a 9" are both considered options on my long term upgrade list .
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: Tig]
#3037672
04/27/22 04:47 PM
04/27/22 04:47 PM
Posts: 1,403 Chesterfield Twp. Mi.
John Burdine
Why do you want to run one of those power robbing turbo 400 trannies in a Mopar? Hmmm......I only know of 2 mopars that have done that swap. Both cars were big tyre chassis cars and they both improved ET with no other changes. But....was it down to a better converter.... or the more efficient 2-3 gear change All I know is a TH400 and a 9" are both considered options on my long term upgrade list . The Reid case is another nice option you cant get for a 727.
[Re: John Burdine]
#3037855
04/28/22 05:10 AM
04/28/22 05:10 AM
Tig
A shed in England
Why do you want to run one of those power robbing turbo 400 trannies in a Mopar? Hmmm......I only know of 2 mopars that have done that swap. Both cars were big tyre chassis cars and they both improved ET with no other changes. But....was it down to a better converter.... or the more efficient 2-3 gear change All I know is a TH400 and a 9" are both considered options on my long term upgrade list . The Reid case is another nice option you cant get for a 727. Indeed, the SFi case is another advantage. After reading another post on how some manufacturers are discontinuing parts for Dana 60's, I think fitting a 9" has moved to the short term upgrade list
[Re: Tig]
#3037878
04/28/22 08:25 AM
04/28/22 08:25 AM
an8sec70cuda
Why do you want to run one of those power robbing turbo 400 trannies in a Mopar? Hmmm......I only know of 2 mopars that have done that swap. Both cars were big tyre chassis cars and they both improved ET with no other changes. But....was it down to a better converter.... or the more efficient 2-3 gear change All I know is a TH400 and a 9" are both considered options on my long term upgrade list . The Reid case is another nice option you cant get for a 727. Indeed, the SFi case is another advantage. After reading another post on how some manufacturers are discontinuing parts for Dana 60's, I think fitting a 9" has moved to the short term upgrade list I saw that too. If money weren't an issue, I'd already have a glide in my car. Parts start getting scarce and I'll be ditching the Dana too. At this point in life, my car has become way less of a priority/moneypit to me. It is what it is. It'll run what it runs w/ what I have already.
