Re: 727 Transmission disassembles issues.
[Re: racerx]
#3034642
04/18/22 12:18 PM
04/18/22 12:18 PM
Posts: 1,606 westerly, ri. usa
440lebaron
westerly, ri. usa
what was condition of trans? why apart? clutches welded together??
all parts are sold as is, all parts are considered used no warranties or returns paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred site is not monitored 24/7 there might be a delay in response
[Re: racerx]
#3034643
04/18/22 12:19 PM
04/18/22 12:19 PM
Posts: 2,110 Byron, NY
W.I.N. Racing
Byron, NY
My guess is it rolled the teeth on the fibers... Pull the tail housing, rear bearing and governor housing then pull the whole mess out the front. That way you can persuade them a part easier.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
[Re: W.I.N. Racing]
#3034665
04/18/22 01:09 PM
04/18/22 01:09 PM
Posts: 25,796 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Could also be a galled input shaft bushing holding the output shaft pilot hub.
Try turning the trans face down on a hard floor, lift a couple of feet and drop it to shock the parts loose.
[Re: 440lebaron]
#3034692
04/18/22 02:22 PM
04/18/22 02:22 PM
Posts: 4,070 Mo.
racerx
Mo.
Its a TB tranny with a aluminum drum, basically it lost reverse.
[Re: John_Kunkel]
#3034693
04/18/22 02:28 PM
04/18/22 02:28 PM
Posts: 4,070 Mo.
racerx
Mo.
Try turning the trans face down on a hard floor, lift a couple of feet and drop it to shock the parts loose. The rear clutch assy will lift about a quarter of an inch out of the sun shell but that's it. It will not go any farther.
[Re: racerx]
#3035043
04/19/22 01:46 PM
04/19/22 01:46 PM
John_Kunkel
Rio Linda, CA
Yes, and when it's missing, the output shaft pilot will bottom out in the input shaft and peen over...trapping it in the input shaft bushing.
[Re: racerx]
#3035345
04/20/22 01:41 PM
04/20/22 01:41 PM
John_Kunkel
Rio Linda, CA
Bronze (bottom right) is preferred for performance builds, the fiber (bottom left) are known to fail probably because of excessive input shaft free play. If either fail there should be broken pieces in the pan.
