727 Transmission disassembles issues. #3034640
04/18/22 12:08 PM
04/18/22 12:08 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Having an issue with pulling the input shaft/clutch assembly from the sun shell in the transmission any ideal what's going on there? Anyone has had this issue before.........Thanks in advance.
Re: 727 Transmission disassembles issues. [Re: racerx] #3034642
04/18/22 12:18 PM
04/18/22 12:18 PM
westerly, ri. usa
440lebaron Offline
440lebaron  Offline
westerly, ri. usa
what was condition of trans? why apart? clutches welded together??
all parts are sold as is, all parts are considered used no warranties or returns
paypal/check/money order, shipping is from zip 02891, buyer pays paypal fees 24% IRS 1099A plus 3% of part price, check/money order preferred
site is not monitored 24/7 there might be a delay in response
Re: 727 Transmission disassembles issues. [Re: racerx] #3034643
04/18/22 12:19 PM
04/18/22 12:19 PM
Byron, NY
W.I.N. Racing Offline
Byron, NY
My guess is it rolled the teeth on the fibers... Pull the tail housing, rear bearing and governor housing then pull the whole mess out the front. That way you can persuade them a part easier. twocents
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: 727 Transmission disassembles issues. [Re: W.I.N. Racing] #3034665
04/18/22 01:09 PM
04/18/22 01:09 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Could also be a galled input shaft bushing holding the output shaft pilot hub.
Try turning the trans face down on a hard floor, lift a couple of feet and drop it to shock the parts loose.
Re: 727 Transmission disassembles issues. [Re: 440lebaron] #3034692
04/18/22 02:22 PM
04/18/22 02:22 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Its a TB tranny with a aluminum drum, basically it lost reverse.
Re: 727 Transmission disassembles issues. [Re: John_Kunkel] #3034693
04/18/22 02:28 PM
04/18/22 02:28 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
The rear clutch assy will lift about a quarter of an inch out of the sun shell but that's it. It will not go any farther.
Re: 727 Transmission disassembles issues. [Re: racerx] #3034825
04/18/22 08:29 PM
04/18/22 08:29 PM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
I think the piston over traveled, and wedged the last clutch plate to the annulus gear.
Re: 727 Transmission disassembles issues. [Re: Leigh] #3034841
04/18/22 08:53 PM
04/18/22 08:53 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Well with some wiggling and pulling on the input shaft i was able to break free the retainers from the the sun shell. There is a thrust washer that sit between the input and output shafts. Under the snap ring it's missing. if i'm not mistaken that thrust washer sits the clearance between the high-speed drum and your planetaries. Is this correct?........Thanks for the help gents
Re: 727 Transmission disassembles issues. [Re: racerx] #3035043
04/19/22 01:46 PM
04/19/22 01:46 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Yes, and when it's missing, the output shaft pilot will bottom out in the input shaft and peen over...trapping it in the input shaft bushing.
Re: 727 Transmission disassembles issues. [Re: John_Kunkel] #3035116
04/19/22 07:28 PM
04/19/22 07:28 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thank you .....ever herd of one disintegrate? i see traces of the bronzes color on the out put shaft I'm not clear on why that happen shruggy.
Re: 727 Transmission disassembles issues. [Re: racerx] #3035333
04/20/22 12:50 PM
04/20/22 12:50 PM
okla.
sam64 Offline
sam64  Offline
okla.
some of those were made of fiber.
Re: 727 Transmission disassembles issues. [Re: racerx] #3035345
04/20/22 01:41 PM
04/20/22 01:41 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Bronze (bottom right) is preferred for performance builds, the fiber (bottom left) are known to fail probably because of excessive input shaft free play. If either fail there should be broken pieces in the pan.
Re: 727 Transmission disassembles issues. [Re: John_Kunkel] #3035464
04/20/22 09:20 PM
04/20/22 09:20 PM
Mo.
racerx Offline OP
racerx  Offline OP
Mo.
Thanks, John, for that info. up
