Re: Edelbrock and 440 Source water pumps
[Re: hemienvy]
#3034411
04/17/22 02:16 PM
04/17/22 02:16 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
I went with a Flowkooler pump when I had some issues with my cooling system and I really like how much coolant it moves even at idle. It's mounted on a Mancini housing. Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
[Re: fourgearsavoy]
#3034419
04/17/22 02:32 PM
04/17/22 02:32 PM
Posts: 760 Southington Ct.
turbobitt
Southington Ct.
I am also using the FlowKooler pump but on a 440 source housing. I had switched out my big aluminum radiator to a more stock appearing Glen Ray radiator with a stock shroud and clutch fan setup and it actually runs cooler than the dual electric fans and aluminum radiator. I was wondering if the water pump was going to be gimmicky but it seems to actually work. FWIW this is on a 572 Hemi with 11:1 compression, aluminum heads and a decent roller cam.
AG.
1970 Challenger w/572 Hemi street car and my pride and joy.
1986 T-Type with 272 Stage 2 Buick V6 engine - True 8 second street car. Just updated the engine and put down 928 HP @ 35# boost to the ground on chasis dyno.
1976 Cee Bee Avenger Jet Boat - 460 Ford powered.
[Re: hemienvy]
#3034434
04/17/22 03:51 PM
04/17/22 03:51 PM
Posts: 2,866 Pattison Texas
CSK
Pattison Texas
I have the 440 source pump & housing, keeps my 512 with cold AC running 185 ish all day long, in the summer heat 106 deg
[Re: Cab_Burge]
#3034891
04/19/22 12:45 AM
04/19/22 12:45 AM
Posts: 3,087 Michigan
A727Tflite
J What is a water manifold on BB Mopar V8s ? The water pump housing.
[Re: hemienvy]
#3035512
04/21/22 01:10 AM
04/21/22 01:10 AM
Posts: 610 Boise
Moparteacher
Boise
I was just looking at the Flow Cooler.
There appears to be two water manifold "depths" for the vanes over the years. Early manifolds with drivers side inlet and later, deeper, with passenger side inlet. Most of the aftermarket pumps appear to be for the early shallower type manifold. Shallow meaning the angled circular floor is not machined as deep. So certain pumps can't be used with this design manifold because the vanes would contact the floor when you bolt the pump down and the pump couldn't turn. And vice versa, a shallow pump in a deep manifold won't cool at all. I put my Flowcooler on an older Canadian made aluminum housing. Used putty to imprint the vane depth. Then had the mounting surface on the housing milled till the vanes barely touched the bottom. Used the gasket to move the vanes off the bottom. Current clearance between vanes and bottom of angled circular floor is .015". Ya' it moves water.
[Re: hemienvy]
#3035630
04/21/22 09:03 AM
04/21/22 09:03 AM
Posts: 1,146 Loudoun County, VA
Brad_Haak
Loudoun County, VA
An Edelbrock pump in an MP aluminum housing worked better for me than an OEM pump in an OEM iron housing. IIRC, the temps while sitting in traffic weren't much different, but the car cooled down faster and temps were more consistent.
2021 Challenger 6.4L Scat Pack 1320 100% stock: 1.680, 11.894 at 113.75 (DA 175 ft) weight reduction, wheels, tires, Hellcat air box: 1.661, 11.686 at 115.97 (DA 710 ft)
1973 Challenger 452 ci street/strip [2008] pump gas, DOT radials: 1.454, 10.523 at 126.44 (DA 514 ft)
