4.5 inch pulley for vacuum pump?
#3031967
04/08/22 08:11 PM
04/08/22 08:11 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
I spotted one months ago but failed to write down where i saw it. I can go a bit smaller than 5 inch for max vacuum. I have a Moroso 3 vane pump.
Re: 4.5 inch pulley for vacuum pump?
[Re: gregsdart]
#3032039
04/09/22 07:30 AM
04/09/22 07:30 AM
Posts: 16,928 NC
440Jim
NC
During the winter, I called Aerospace components, they make a popular vacuum pump. They said the biggest they make for their crank mandrel was 5" (not 4")
[Re: gregsdart]
#3032059
04/09/22 09:51 AM
04/09/22 09:51 AM
Posts: 6,334 Heaven
EvilB1Dart
Heaven
I spotted one months ago but failed to write down where i saw it. I can go a bit smaller than 5 inch for max vacuum. I have a Moroso 3 vane pump. Greg a buddy of mine ordered his 4.5” pulley from Butler Performance. I assume you’re referring to the pump pulley, and not the crank mandrel pulley. https://butlerperformance.com/i-249...r-6-5-dia-v-belt-gz-vpp-401-402-404.html
"Any fool can know. The point is to understand"
- A. Einstein
[Re: gregsdart]
#3032412
04/10/22 06:59 PM
04/10/22 06:59 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
With a 3 vane you cant pull enough to hurt anything. Lots of old wives tales about vacuum for sure. Jones make a lot of pullies for accessories.
[Re: Al_Alguire]
#3032521
04/11/22 08:34 AM
04/11/22 08:34 AM
gregsdart
With a 3 vane you cant pull enough to hurt anything. Lots of old wives tales about vacuum for sure. Jones make a lot of pullies for accessories. Al, care to elaborate on vacuum wives tails? This is uncharted teritory for me and i don't want to hurt my very costly new build!
[Re: gregsdart]
#3032594
04/11/22 12:57 PM
04/11/22 12:57 PM
Al_Alguire
Las Vegas
A 3 vane pump simply will NOT pull enough vacuum to hurt anything. 11-12" is all they can pull generally. If someone says they get more from one in a BBM with a wet sump oiling system gonna have to show me with an accurate gauge that it happened. We never have regulated a 3 vane engine of any kindand never seen an issue.
I have NEVER seen an issues from "high" vacuum in anything I run or have been around. My Cuda routinely went 400+ passes between freshen ups. The pistons in that engine currently had 406 passes on them at freshen up, we coated and reused them and its still running them 7 years later. Never any issues with wrist pins and it pulls 16-18" every pass, or at least did. Literally a couple thousand runs on it before I sold it. Been running vacuum pumps for 15 years and never seen any issues of "pulling oil away from pins" in any of my junk. I have seen some Comp stuff that pulls 22-26" of vacuum with no signs of pin oiling issues. Wealso have not had any issues on the Vette running 18-20. It uses a 4 vane and no regulator.
[Re: PETE@BESTMACHINE]
#3034011
04/16/22 02:39 AM
04/16/22 02:39 AM
gregsdart
We use a lot of 3-vane Moroso vacuum pumps with a regulator and have had over 16 " vacuum often. Check out our Facebook page for pictures and dyno sheets. Thanks Pete. Hopefully i will get more than 12". My pulley ratio with the 4.5 will be right at or a touch above recommended punp rpm.
