4.5 inch pulley for vacuum pump? #3031967
04/08/22 08:11 PM
04/08/22 08:11 PM
gregsdart Offline OP
I spotted one months ago but failed to write down where i saw it. I can go a bit smaller than 5 inch for max vacuum. I have a Moroso 3 vane pump.
Re: 4.5 inch pulley for vacuum pump? [Re: gregsdart] #3032039
04/09/22 07:30 AM
04/09/22 07:30 AM
NC
440Jim Offline
440Jim  Offline
NC
During the winter, I called Aerospace components, they make a popular vacuum pump. They said the biggest they make for their crank mandrel was 5" (not 4")
Re: 4.5 inch pulley for vacuum pump? [Re: gregsdart] #3032054
04/09/22 08:57 AM
04/09/22 08:57 AM
Anoka County, MN
Leigh Offline
Leigh  Offline
Anoka County, MN
Greg, have you tried Jones Racing Products?
Re: 4.5 inch pulley for vacuum pump? [Re: gregsdart] #3032059
04/09/22 09:51 AM
04/09/22 09:51 AM
Heaven
EvilB1Dart Offline
EvilB1Dart  Offline
Heaven
Greg a buddy of mine ordered his 4.5” pulley from Butler Performance. I assume you’re referring to the pump pulley, and not the crank mandrel pulley.
https://butlerperformance.com/i-249...r-6-5-dia-v-belt-gz-vpp-401-402-404.html
"Any fool can know. The point is to understand"
- A. Einstein
Re: 4.5 inch pulley for vacuum pump? [Re: EvilB1Dart] #3032073
04/09/22 11:26 AM
04/09/22 11:26 AM
Thanks guys, Wes, that was it! Ordered a 4.5. Best price too.
Re: 4.5 inch pulley for vacuum pump? [Re: gregsdart] #3032412
04/10/22 06:59 PM
04/10/22 06:59 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
With a 3 vane you cant pull enough to hurt anything. Lots of old wives tales about vacuum for sure. Jones make a lot of pullies for accessories.
Re: 4.5 inch pulley for vacuum pump? [Re: Al_Alguire] #3032521
04/11/22 08:34 AM
04/11/22 08:34 AM
Al, care to elaborate on vacuum wives tails? This is uncharted teritory for me and i don't want to hurt my very costly new build!
Re: 4.5 inch pulley for vacuum pump? [Re: gregsdart] #3032594
04/11/22 12:57 PM
04/11/22 12:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A 3 vane pump simply will NOT pull enough vacuum to hurt anything. 11-12" is all they can pull generally. If someone says they get more from one in a BBM with a wet sump oiling system gonna have to show me with an accurate gauge that it happened. We never have regulated a 3 vane engine of any kindand never seen an issue.
I have NEVER seen an issues from "high" vacuum in anything I run or have been around. My Cuda routinely went 400+ passes between freshen ups. The pistons in that engine currently had 406 passes on them at freshen up, we coated and reused them and its still running them 7 years later. Never any issues with wrist pins and it pulls 16-18" every pass, or at least did. Literally a couple thousand runs on it before I sold it. Been running vacuum pumps for 15 years and never seen any issues of "pulling oil away from pins" in any of my junk. I have seen some Comp stuff that pulls 22-26" of vacuum with no signs of pin oiling issues. Wealso have not had any issues on the Vette running 18-20. It uses a 4 vane and no regulator.
Re: 4.5 inch pulley for vacuum pump? [Re: Al_Alguire] #3033594
04/14/22 04:02 PM
04/14/22 04:02 PM
SouthEast Michigan
P
PETE@BESTMACHINE Offline
P
SouthEast Michigan
We use a lot of 3-vane Moroso vacuum pumps with a regulator and have had over 16 " vacuum often. Check out our Facebook page for pictures and dyno sheets.
Re: 4.5 inch pulley for vacuum pump? [Re: PETE@BESTMACHINE] #3034011
04/16/22 02:39 AM
04/16/22 02:39 AM
Thanks Pete. Hopefully i will get more than 12". My pulley ratio with the 4.5 will be right at or a touch above recommended punp rpm.
