Power steering pump shaft end play ? #3030432
04/03/22 10:27 PM
04/03/22 10:27 PM
USA
Grizzly69 Offline OP
USA
How much in and out slop is acceptable on a power steering pump shaft ?
I just bought a remanufactured Saginaw style pump, and when I went to install the pulley I noticed what seems to me to be excessive in and out movement on the shaft. about 0.060" or 1/16", possibly more.
So, how much movement is too much ?
Please be specific.
Re: Power steering pump shaft end play ? [Re: Grizzly69] #3030460
04/04/22 03:20 AM
04/04/22 03:20 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
normal !
Re: Power steering pump shaft end play ? [Re: calrobb2000] #3030515
04/04/22 10:35 AM
04/04/22 10:35 AM
moparx Offline
moparx  Offline
agree, this is normal. the saginaw pump on my charger is the original unit, and has almost 19k original miles on it.
no leaks or noises, works as it should.
beer
Re: Power steering pump shaft end play ? [Re: moparx] #3030528
04/04/22 11:02 AM
04/04/22 11:02 AM
USA
USA
Ok, thanks,
I guess I'll try it, but it sure seems like a lot of movement.
Re: Power steering pump shaft end play ? [Re: Grizzly69] #3030563
04/04/22 12:46 PM
04/04/22 12:46 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I built a lot of pumps while working at the dealer. They always have a ton of end play.
Doug
Re: Power steering pump shaft end play ? [Re: Grizzly69] #3031097
04/06/22 12:12 AM
04/06/22 12:12 AM
minot north dakota
ledft79 Offline
ledft79  Offline
minot north dakota
I don't think that I've ever seen a working PS pump that didn't have 1/8"+ of end play. Totally normal and probably necessary for some reason.
DRIVE EM, DONT HIDE EM.
Re: Power steering pump shaft end play ? [Re: ledft79] #3031228
04/06/22 12:37 PM
04/06/22 12:37 PM
St. Charles, MO
wingman Offline
Uncreative Title
wingman  Offline
Uncreative Title
St. Charles, MO
When I rebuilt my leaking Saginaw years ago I worried about the same thing. I put it in and it ran perfectly for years. shruggy
Don't call it "slop"--call it a "self-aligning pulley" if it makes you feel better... grin
1969 Dodge Coronet Super Bee 383 A4
1970 Plymouth Road Runner 440 FC7 (sold)
