Sandblasting a pulley #3030130
04/03/22 01:14 AM
04/03/22 01:14 AM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
Should you blast inside the Vee ?
Would that make the belt surface a bit too rough ?
How about painting inside the Vee ?
Re: Sandblasting a pulley [Re: hemienvy] #3030135
04/03/22 02:07 AM
04/03/22 02:07 AM
South Bend
John Brown Offline
John Brown  Offline
South Bend
If just needing paint removal, I soak them in lye. Lye doesn't attack iron or steel, but it turns paint into goo that falls off or washes off. Leave the pulley in the lye for several hours, depending on how strong of a solution you have.
Re: Sandblasting a pulley [Re: John Brown] #3030146
04/03/22 06:09 AM
04/03/22 06:09 AM
rust belt
Moparite Offline
Moparite  Offline
rust belt
I blast and paint them, Never had a issue.
Re: Sandblasting a pulley [Re: Moparite] #3030150
04/03/22 07:44 AM
04/03/22 07:44 AM
new berlin wisconsin
Mr T2U Offline
Mr T2U  Offline
blast and paint.
IF blasting roughs up the inner surface the belt will smooth everything out asap when running. and in my OPINION, the rough part won't wear out the belt.
perception is 90% of reality
Re: Sandblasting a pulley [Re: Moparite] #3030151
04/03/22 07:45 AM
04/03/22 07:45 AM
Mass
charge70 Offline
charge70  Offline
Mass
Same here.No problems.
1970 Dodge Charger R/T S.E. 1969 Dodge Dart GTS 440 M-Code 1970 Dodge Charger 500 383/4-speed w/A.C.
Re: Sandblasting a pulley [Re: charge70] #3030159
04/03/22 08:31 AM
04/03/22 08:31 AM
VA
dragon slayer Offline
VA
I wouldn't use something that roughens the metal surface. Use glass. If the pully Vee is badly rusted, might want to pick a different pulley. I bead blast them and wire brush the Vee (with bench grinder). Paint. Paint in V will rub off with belt.
Re: Sandblasting a pulley [Re: dragon slayer] #3030173
04/03/22 10:14 AM
04/03/22 10:14 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
I sandblast/glassbead pulleys completely, have been for decades, paint the entire thing, the belt will remove the paint with no ill effects to either, powdercoating is the only process that causes issues...
Re: Sandblasting a pulley [Re: DAYCLONA] #3030220
04/03/22 12:26 PM
04/03/22 12:26 PM
Washington
hemienvy Offline OP
hemienvy  Offline OP
Washington
OK , Thanks gents, one less thing to wonder about.
Re: Sandblasting a pulley [Re: hemienvy] #3033938
04/15/22 08:31 PM
04/15/22 08:31 PM
Pittsburgh,PA
RTSrunner Offline
RTSrunner  Offline
Pittsburgh,PA
If you have anyone in your area that does vapor blasting that would leave the best finish on your pulley drive surface. I recently purchased a vapor blast cabinet for my motorcycle shop and it is awesome.With the media suspended in water it blasts indirectly,the finish left behind is smooth and shiny VS the dry/dull finish of dry blast. Bare steel seems to be resistant to flash rust and it wont remove any stamped in numbers either. I bought it to do mostly aluminum parts and use glass bead mixed with the water.
https://vaporhoningtechnologies.com/
Re: Sandblasting a pulley [Re: RTSrunner] #3034060
04/16/22 09:36 AM
04/16/22 09:36 AM
WV
Little Detroit Offline
WV
degrease and then EVAPO_RUST< RINSE and paint
