Re: Sandblasting a pulley
[Re: hemienvy]
#3030135
04/03/22 02:07 AM
04/03/22 02:07 AM
Posts: 1,841 South Bend
John Brown
South Bend
If just needing paint removal, I soak them in lye. Lye doesn't attack iron or steel, but it turns paint into goo that falls off or washes off. Leave the pulley in the lye for several hours, depending on how strong of a solution you have.
[Re: Moparite]
#3030150
04/03/22 07:44 AM
04/03/22 07:44 AM
Posts: 4,923 new berlin wisconsin
Mr T2U
blast and paint. IF blasting roughs up the inner surface the belt will smooth everything out asap when running. and in my OPINION, the rough part won't wear out the belt.
perception is 90% of reality
[Re: Moparite]
#3030151
04/03/22 07:45 AM
04/03/22 07:45 AM
Posts: 601 Mass
charge70
Mass
I blast and paint them, Never had a issue. Same here.No problems.
1970 Dodge Charger R/T S.E.
1969 Dodge Dart GTS 440 M-Code
1970 Dodge Charger 500 383/4-speed w/A.C.
[Re: dragon slayer]
#3030173
04/03/22 10:14 AM
04/03/22 10:14 AM
Posts: 18,157 Mass
DAYCLONA
Mass
I wouldn't use something that roughens the metal surface. Use glass. If the pully Vee is badly rusted, might want to pick a different pulley. I bead blast them and wire brush the Vee (with bench grinder). Paint. Paint in V will rub off with belt. I sandblast/glassbead pulleys completely, have been for decades, paint the entire thing, the belt will remove the paint with no ill effects to either, powdercoating is the only process that causes issues...
