Re: would race fuel help
[Re: GEORGE68HEMIRR]
#302756
04/29/09 12:34 AM
04/29/09 12:34 AM
Posts: 52,972 Romeo MI
MR_P_BODY
With all of the alum you have it should stay pretty cool and if its tuned correctly for the 93 it shouldnt be a problem ![](/ubbthreads/images/graemlins/wave.gif)
#302758
04/29/09 11:10 AM
04/29/09 11:10 AM
Posts: 3,287 West Coast, USA
jbc426
West Coast, USA
I'd put a wideband on it and see if that fuel pump was running out of juice well before the traps. You're feeding a lot of carb there.
1970 Plymouth 'Cuda #'s 440-6(block in storage)currently 493" 6 pack, Shaker, 5 speed Passon, 4.10's 1968 Plymouth Barracuda Convertible 408 Magnum EFI with 4 speed automatic overdrive, 3800 stall lock-up converter and 4.30's (closest thing to an automatic 5 speed going)
[Re: rebel]
#302759
04/29/09 01:13 PM
04/29/09 01:13 PM
Posts: 8,165 Left Coast
BobR
Left Coast
each to their own, but if that was my engine with that compression & cam, i'd run 103-105 octane. our fuel might have a different rating but even so i'd take a jug of higher rated gas & try it out. you'd have to bump up the timing a bit but if it meant going faster i'd try anything.
I agree. Detonation cannot always be detected until your rod bearings drop out of the saddles. I understand what Mike is saying about the aluminum but with 11.5-1 I would use some amount of race gas-just to be safe.
[Re: BobR]
#302760
04/29/09 03:00 PM
04/29/09 03:00 PM
Posts: 878 hudson valley n.y.
GEORGE68HEMIRR
super street
super street
hudson valley n.y.
what octane should i use??
