What intake will fit a 98 5.9 magnum
#3025561
03/19/22 09:16 PM
03/19/22 09:16 PM
Posts: 12,587 Great Neck,LI,new york
hemi-itis
for a carb? I picked up a 1998 5.9 magnum from a 1500 pick up for my 88 Diplomat. I want to use a carb and need an intake. What say you small block guys?
Re: What intake will fit a 98 5.9 magnum
[Re: hemi-itis]
#3025566
03/19/22 09:37 PM
03/19/22 09:37 PM
Posts: 20,184 Park Forest, IL
slantzilla
Park Forest, IL
I have a Weiand X-Cellerator that has some of the bolt holes ovalled out. I was told it had been on a Magnum motor.
[Re: cudaman1969]
#3025571
03/19/22 09:43 PM
03/19/22 09:43 PM
Guitar Jones
If you want to keep the front accessory drive with the A/C compressor the only choice for new is the Edelbrock Air Gap for the magnum. There are other knock off intakes made for the magnum heads but the water outlet is in the wrong place to keep the compressor. You could search on the Summit site by engine.
[Re: Guitar Jones]
#3025687
03/20/22 11:14 AM
03/20/22 11:14 AM
hemi-itis
If you want to keep the front accessory drive with the A/C compressor the only choice for new is the Edelbrock Air Gap for the magnum. There are other knock off intakes made for the magnum heads but the water outlet is in the wrong place to keep the compressor. You could search on the Summit site by engine. I absolutley want to keep the A/C!! Thanks for the heads up!
