What intake will fit a 98 5.9 magnum #3025561
03/19/22 09:16 PM
03/19/22 09:16 PM
Great Neck,LI,new york
hemi-itis Offline OP
for a carb? I picked up a 1998 5.9 magnum from a 1500 pick up for my 88 Diplomat. I want to use a carb and need an intake.
What say you small block guys?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: What intake will fit a 98 5.9 magnum [Re: hemi-itis] #3025566
03/19/22 09:37 PM
03/19/22 09:37 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I have a Weiand X-Cellerator that has some of the bolt holes ovalled out. I was told it had been on a Magnum motor.
Re: What intake will fit a 98 5.9 magnum [Re: hemi-itis] #3025568
03/19/22 09:39 PM
03/19/22 09:39 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Pickens are slim and none, years ago I bought the M1 from Chrysler and I think the aftermarket made one to. Drill the heads and then use any 340-360 intake. Someone on here made a jig but brain fade can’t remember who.
Re: What intake will fit a 98 5.9 magnum [Re: cudaman1969] #3025571
03/19/22 09:43 PM
03/19/22 09:43 PM
Guitar Jones Offline
If you want to keep the front accessory drive with the A/C compressor the only choice for new is the Edelbrock Air Gap for the magnum. There are other knock off intakes made for the magnum heads but the water outlet is in the wrong place to keep the compressor.
You could search on the Summit site by engine.
Re: What intake will fit a 98 5.9 magnum [Re: Guitar Jones] #3025685
03/20/22 11:12 AM
03/20/22 11:12 AM
Re: What intake will fit a 98 5.9 magnum [Re: Guitar Jones] #3025687
03/20/22 11:14 AM
03/20/22 11:14 AM
I absolutley want to keep the A/C!! Thanks for the heads up!
