Super Stock springs sag? #3023776
03/13/22 10:21 PM
03/13/22 10:21 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
Can SS springs sag over time? Mine (#454/455) are 20 years old and seem to be sitting lower.
Re: Super Stock springs sag? [Re: Jeff_383] #3023780
03/13/22 10:34 PM
03/13/22 10:34 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
The newer ones are horrible about losing arch. Made in Mexico garbage! It took mine way less time than that to lose their arch. Mine were 456/457.
'63 Dodge 330
11.19 @ 121 mph
Re: Super Stock springs sag? [Re: GY3] #3023784
03/13/22 10:43 PM
03/13/22 10:43 PM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
I don't remember where mine were made. It's been since 2002 I think, maybe 01 even.
Re: Super Stock springs sag? [Re: Jeff_383] #3023804
03/14/22 12:11 AM
03/14/22 12:11 AM
Great Neck,LI,new york
hemi-itis Online content
hemi-itis  Online Content
Go with Cal Trac system,you wont be sorry,don't cheao out on shocks!
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: Super Stock springs sag? [Re: hemi-itis] #3023806
03/14/22 12:31 AM
03/14/22 12:31 AM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
That's a good question. Money isn't great and ss springs are a little less than 300 dollars. A whole caltrac set up is like 1000 or so. That is a sig amount. I also kinda dig the higher stance of the ss springs too. I don't want to be cheap, although I do need to be watchful.
Re: Super Stock springs sag? [Re: Jeff_383] #3023816
03/14/22 03:12 AM
03/14/22 03:12 AM
You might want a better set of the SS drag racing springs from Gregg Luneack at Tri City Competition in SO CA up scope
i hope he is still in business luck confused
Re: Super Stock springs sag? [Re: Cab_Burge] #3023827
03/14/22 06:06 AM
03/14/22 06:06 AM
Pittsburgh, Pa
Jeff_383 Offline OP
Jeff_383  Offline OP
Pittsburgh, Pa
I read he is not due to high supply costs.
Re: Super Stock springs sag? [Re: Jeff_383] #3023845
03/14/22 08:32 AM
03/14/22 08:32 AM
New York, USA
Chargerfan68 Offline
New York, USA
I used new SS springs in 2006 on my 68 b body when I first put on MT drag radials. After a few launches on the street, They permanently bent the front segnent of the leafs. Such severe spring wrap up. I kept throwing pinion snubber bumpers off the car with them. They were complete garbage! I took ‘em out that week and put in Caltracs. 16 years on Caltracs and no sag at all and hook very consistently. They do offer +1” height, which I got on mine.
Re: Super Stock springs sag? [Re: Chargerfan68] #3023852
03/14/22 09:06 AM
03/14/22 09:06 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
That's about the time I bought mine. They were bent so much it was killing the driveshaft straps on the rear yoke.
We did the Cal-Trac setup as well and the car launches level and much more consistent.
'63 Dodge 330
11.19 @ 121 mph
Re: Super Stock springs sag? [Re: Chargerfan68] #3023854
03/14/22 09:07 AM
03/14/22 09:07 AM
Mo.
racerx Offline
racerx  Offline
Mo.
On the subject of SS springs anyone no if the E/B body springs interchange?...Thanks wave
Re: Super Stock springs sag? [Re: racerx] #3023882
03/14/22 10:36 AM
03/14/22 10:36 AM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
I have buddies who have had SS springs on back order forever for B Bodies. I went with -1" split mono leafs and Caltracs on my Challenger to get it a little lower since I have 30" tall tires.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
Re: Super Stock springs sag? [Re: Jeff_383] #3023923
03/14/22 12:09 PM
03/14/22 12:09 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
. Try Point Spring in Pittsburgh, they may be able to “re arch” them for you.
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: Super Stock springs sag? [Re: Jeff_383] #3024251
03/15/22 02:47 PM
03/15/22 02:47 PM
Columbus, GA
Michael Ecks Offline
Columbus, GA
If you are just looking for the stance, you can order regular or heavy duty springs from ESPO Springs and Things and specify additional arch made into them.
"The happiness of your life depends upon the quality of
your thoughts" ~ Roman Emperor Marcus Aurelius
Re: Super Stock springs sag? [Re: Jeff_383] #3024299
03/15/22 04:32 PM
03/15/22 04:32 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
My 454/455 springs haven't appreciably sagged in the last 20 or so years....That I have noticed!
but, full disclosure, I bought them used/second hand
and the seller claimed a reputable local spring shop, John R. Spring had reworked them.
I think the springs already did whatever they were going to do and were probably fixed.
They had added a leaf, but beyond that.....I don't know what other work they did.
The ride height was ridiculous with the added leaf.
I took the added leaf out, shortened up the center bolt to match, and have used them that way for many years.
My experience is not typical if I can believe what folks have told me over the years... and I usually don't mention it.....
....but if budget is an issue it might be worthwhile to have a spring shop bring them back up to snuff.
Rich H.
Esse Quam Videri
Re: Super Stock springs sag? [Re: ZIPPY] #3024300
03/15/22 04:36 PM
03/15/22 04:36 PM
Chesterfield Twp. Mi.
John Burdine Offline
Caltrac monoleafs will de-arch as well. Especially the rh leaf.
Re: Super Stock springs sag? [Re: racerx] #3024318
03/15/22 05:48 PM
03/15/22 05:48 PM
It may depend on which year B body spring you're wanting to use, pre 1964 B bodies used a shorter front half spring than the 1964 and later.
I think all the E body springs have a 22.0 inch long front half and they were mounted sideways in relation to the rear subframes, the front mounts are wider apart than the rear mounts are shruggy
I'm not sure if they will swap okay or not, sorry blush
Re: Super Stock springs sag? [Re: Cab_Burge] #3024394
03/15/22 09:07 PM
03/15/22 09:07 PM
Mo.
racerx Offline
racerx  Offline
Mo.
Thanks Cab wave
Re: Super Stock springs sag? [Re: John Burdine] #3024395
03/15/22 09:14 PM
03/15/22 09:14 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
iagree I had Cal-Tracs on my Savoy for a few seasons then they completely lost their arch and were flat after about 90 passes and some street miles. Took them off and went back to 454-55 springs about 6 years ago and they still have the good arch shruggy
Gus beer
64 Plymouth Savoy
Dana 60
Re: Super Stock springs sag? [Re: Jeff_383] #3024909
03/17/22 03:25 PM
03/17/22 03:25 PM
Irving, TX
feets Offline
Senior Management
feets  Offline
Senior Management
Irving, TX
I made the SS springs for my 65 Belvedere.
I took 1969 B body springs and swapped the pack onto the shorter 65 main leaf. There were two half leafs on the right and one on the left.
It planted the tires evenly and didn't sag over the 15 years I had the car.
- Stu Harmon
Re: Super Stock springs sag? [Re: fourgearsavoy] #3024923
03/17/22 04:22 PM
03/17/22 04:22 PM
New York, USA
New York, USA
Gus beer
Very surprised to hear that. Then it must be a crap shoot. Mine are 16 yrs old. About 120 drag passes and thousands of street miles and no sag at all. SS springs bent permanently for my car. I guess you just don’t know.
