Rear shock angle on new 4 link setup
#3022788
03/11/22 02:36 AM
03/11/22 02:36 AM
Posts: 1,264 New York, USA
Chargerfan68
New York, USA
I’ve always thought it is better to have the rear shocks installed vertical rather than slightly angled on drag cars (w/ 4 link). Is this true? Any benefit to installing them at 6 deg tilt?
Re: Rear shock angle on new 4 link setup
[Re: fbs63]
#3022815
03/11/22 09:37 AM
03/11/22 09:37 AM
Chargerfan68
New York, USA
None on a drag car. Any angle affects damping and spring rates required. That’s what i always thought…..but wondering why Alston offers 6 degree offset lower shock mounts. I’ll go with 0 degree. Thank you
[Re: Chargerfan68]
#3022818
03/11/22 10:00 AM
03/11/22 10:00 AM
Posts: 4,675 On the parachute mount
n20mstr
None on a drag car. Any angle affects damping and spring rates required. That’s what i always thought…..but wondering why Alston offers 6 degree offset lower shock mounts. I’ll go with 0 degree. Thank you 6* Is what is recommended so the spring doesnt contact the brackets....SW explains that in their rear housing shock bracket instructions.
....BAD A$$ STREET CAR.....
[Re: n20mstr]
#3022859
03/11/22 12:30 PM
03/11/22 12:30 PM
Posts: 8,248 fredericksburg,va
cudaman1969
fredericksburg,va
I had mine on the front of axel at about 30 degree, very soft in the rear and would hook on snot (121 60) This was a Alston recommendation back in the day. In fact I talked with B Glidden once and he showed me on his car how soft he wanted it to be by pushing down on back of car. I was all eyes and ears, the god had spoken.
[Re: cudaman1969]
#3022909
03/11/22 01:36 PM
03/11/22 01:36 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Slightly forward at the top is common to get the attachment closer to being over the housing. Straight up and down is also fine. Never back. I'll even see them tilted in towards the center of the car occasionally for clearance/packaging, but that is typically straight up .
[Re: CMcAllister]
#3022938
03/11/22 02:49 PM
03/11/22 02:49 PM
Posts: 19,385 north of coder
moparx
i have always used the speedway motors chart to determine coil rate to mounting angle for shock mounting points. 90 degrees is always perfect, but if you need to angle the shock, this chart may be helpful. although it shows the shock angled toward the middle of the car, i think it would apply to a forward or rearward angle as well. hope this helps in some way.
[Re: moparx]
#3022954
03/11/22 03:24 PM
03/11/22 03:24 PM
Posts: 4,206 New York
polyspheric
New York
The math is wrong, it's not simple division but trigonometry. 45 degrees is not 50% but 70.7% (cosine of the angle)
Boffin Emeritus
[Re: polyspheric]
#3022967
03/11/22 04:24 PM
03/11/22 04:24 PM
Posts: 4,565 Motor City
6PKRTSE
Motor City
My rear shocks are now vertical even with leafs.
1963 Belvedere 440 Max Wedge Tribute 1970 Charger R/T S.E. 440 Six Pack 1970 Challenger R/T, 528 Hemi 1970 Charger 500 S.E. 440 4 BBL 1970 Plymouth Road Runner 383 1974 Chrysler New Yorker 440 1996 2500 RAM 488 V-10 4X4 2004 3500 Dually Cummins 4x4 2012 Challenger R/T Classic.
