Rear shock angle on new 4 link setup #3022788
03/11/22 02:36 AM
03/11/22 02:36 AM
New York, USA
Chargerfan68 Offline OP
New York, USA
I’ve always thought it is better to have the rear shocks installed vertical rather than slightly angled on drag cars (w/ 4 link). Is this true? Any benefit to installing them at 6 deg tilt?
Re: Rear shock angle on new 4 link setup [Re: Chargerfan68] #3022804
03/11/22 08:17 AM
03/11/22 08:17 AM
NW Indiana
fbs63 Offline
fbs63  Offline
NW Indiana
None on a drag car. Any angle affects damping and spring rates required.
Re: Rear shock angle on new 4 link setup [Re: fbs63] #3022815
03/11/22 09:37 AM
03/11/22 09:37 AM
New York, USA
New York, USA
That’s what i always thought…..but wondering why Alston offers 6 degree offset lower shock mounts. I’ll go with 0 degree.
Thank you
Re: Rear shock angle on new 4 link setup [Re: Chargerfan68] #3022818
03/11/22 10:00 AM
03/11/22 10:00 AM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Thank you
6* Is what is recommended so the spring doesnt contact the brackets....SW explains that in their rear housing shock bracket instructions.
....BAD A$$ STREET CAR.....
Re: Rear shock angle on new 4 link setup [Re: n20mstr] #3022859
03/11/22 12:30 PM
03/11/22 12:30 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
I had mine on the front of axel at about 30 degree, very soft in the rear and would hook on snot (121 60) This was a Alston recommendation back in the day. In fact I talked with B Glidden once and he showed me on his car how soft he wanted it to be by pushing down on back of car. I was all eyes and ears, the god had spoken.
Re: Rear shock angle on new 4 link setup [Re: cudaman1969] #3022909
03/11/22 01:36 PM
03/11/22 01:36 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
Slightly forward at the top is common to get the attachment closer to being over the housing. Straight up and down is also fine. Never back. I'll even see them tilted in towards the center of the car occasionally for clearance/packaging, but that is typically straight up .
Re: Rear shock angle on new 4 link setup [Re: CMcAllister] #3022938
03/11/22 02:49 PM
03/11/22 02:49 PM
moparx Offline
moparx  Offline
i have always used the speedway motors chart to determine coil rate to mounting angle for shock mounting points.
90 degrees is always perfect, but if you need to angle the shock, this chart may be helpful.
although it shows the shock angled toward the middle of the car, i think it would apply to a forward or rearward angle as well.
hope this helps in some way.
beer
Re: Rear shock angle on new 4 link setup [Re: moparx] #3022954
03/11/22 03:24 PM
03/11/22 03:24 PM
New York
polyspheric Offline
polyspheric  Offline
New York
The math is wrong, it's not simple division but trigonometry.
45 degrees is not 50% but 70.7% (cosine of the angle)
Boffin Emeritus
Re: Rear shock angle on new 4 link setup [Re: polyspheric] #3022967
03/11/22 04:24 PM
03/11/22 04:24 PM
Motor City
6PKRTSE Offline
6PKRTSE  Offline
Motor City
My rear shocks are now vertical even with leafs.
1963 Belvedere 440 Max Wedge Tribute
1970 Charger R/T S.E. 440 Six Pack
1970 Challenger R/T, 528 Hemi
1970 Charger 500 S.E. 440 4 BBL
1970 Plymouth Road Runner 383
1974 Chrysler New Yorker 440
1996 2500 RAM 488 V-10 4X4
2004 3500 Dually Cummins 4x4
2012 Challenger R/T Classic.
